September 20, 2024, 01:57:15 am
All Things Mk5
Mk5 General Area
New south column boost pod
Topic: New south column boost pod (Read 1608 times)
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
If you're smart in this world they call you crazy
My Ride:
November 28, 2014, 10:10:05 pm »
Hi, does the new south steering column pod sit directly on top of the steering column trim or do you remove the standard plastic on top of the column and then place the new south on where the original plastic trim was?
Tfsi_Mike
Just look at my post count
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Re: New south column boost pod
Reply #1 on:
November 28, 2014, 11:18:12 pm »
I believe you replace the existing trim
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
My Ride:
Re: HELP. New south column boost pod
Reply #2 on:
November 29, 2014, 12:52:36 pm »
Right it all wired up etc but when I start it up the needle goes to 20 in hg on idle and when I rev it it's goes to 0 regardless of revs. So is this ok? Just don't want to screw the car back together to find I've got a fault. I haven't drive the car yet as it's in bits I've just reved it on the drive way
v4rley
-Given: 29
-Receive: 104
Reply #3 on:
November 29, 2014, 02:56:43 pm »
Yeah sounds right, think it will only boost under load! Get itnput back together and go for a drive
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
My Ride:
Reply #4 on:
November 29, 2014, 03:09:23 pm »
Just got back from a drive, peaks at 12-13 then holds at 10psi, I'm sure I've read on here it should be 22psi? I'm totally stock minus the boost gauge. Does my figures sound right?
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #5 on:
November 29, 2014, 03:18:39 pm »
Sounds correct for a stock gti. See log below.
05 | Tornado Red | DSG
All Things Mk5
Mk5 General Area
