Author Topic: Battery issue  (Read 1391 times)
Offline PaulED30
  • -Given: 19
Battery issue
« on: November 29, 2014, 03:28:22 pm »
Last weekend I got the chrome switch kit and fitted them all except the fuel filler switch because I didnt to have time and I have just fitted it now, it works and so do all the windows and the headlights. The only slight problem is that now my car won't start, or even tick over it just flashes all it's lights and makes a strange noise as if it's trying to tick over.
Could something behind the door panel cause such a big problem?
« Last Edit: November 29, 2014, 03:44:35 pm by PaulED30 »
Offline th3_f15t
  • -Receive: 183
Re: Ahhhhhhhh help!!!!!!
« Reply #1 on: November 29, 2014, 03:30:08 pm »
Possible dying battery..?
Offline PaulED30
  • -Given: 19
« Reply #2 on: November 29, 2014, 03:34:06 pm »
I ve been sat in the car with radio on for 10 mins waiting to try again and just before changing the switch id been out in it so was driving and starting fine then?
How can this be  :sad1:
Offline Wash
« Reply #3 on: November 29, 2014, 03:34:57 pm »
Is it turning over? Or is it just making a ticking sound when you try to start it? If it's the latter then try starting it with a jump. Sounds like your battery is goosed or perhaps something is draining it.
Sent from my SM-G900F using Tapatalk
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: November 29, 2014, 03:37:16 pm »
Lights and radio draw little power compared to the starter motor. If you've had lights and radio on while working it may of drained the battery enough that it can't drive the starter motor.
Also, check that the starter motor isn't burnt out, as this can happen too.
Offline PaulED30
  • -Given: 19
« Reply #5 on: November 29, 2014, 03:40:38 pm »
Going to try jump it now see if that works
Offline PaulED30
  • -Given: 19
Re: Battery issue
« Reply #6 on: November 29, 2014, 03:51:23 pm »
That worked but it's made me more worried about a battery drain issue somewhere, it took about 40 mins to change the switch, only had the radio after it was changed and I'd turned the ignition on to check the switch was working put the door card back on and then it wouldn't start, should I change the battery as a precaution or wait see how it is?
Offline Wash
Re: Battery issue
« Reply #7 on: November 29, 2014, 03:57:39 pm »
Is it the original battery?
Offline PaulED30
  • -Given: 19
Re: Battery issue
« Reply #8 on: November 29, 2014, 04:05:12 pm »
I'm not sure, don't have anything to say it's been changed before
Offline Wash
Re: Battery issue
« Reply #9 on: November 29, 2014, 04:09:26 pm »
Halfords can check for free if your battery is goosed or not. If it's the original battery then chances are it could be on its way out since it will be a fair few years old now.
Offline th3_f15t
  • -Receive: 183
Re: Battery issue
« Reply #10 on: November 29, 2014, 04:17:44 pm »
Take it for a drive, charge it up, then leave it over night and see how it is in the morning. If there's any problems, get it checked for free and go from there.
Offline PaulED30
  • -Given: 19
Re: Battery issue
« Reply #11 on: November 29, 2014, 04:21:38 pm »
Thanks for the help you guys I'll see how it is later
Offline th3_f15t
  • -Receive: 183
Re: Battery issue
« Reply #12 on: November 29, 2014, 06:49:26 pm »
One bit of advice, if your battery is struggling, rip it out, check the water levels (make sure you use deionised water) and give it a long trickle charge to recondition it. Saved a few batteries in my time doing that.
