Author Topic: Airbag fault  (Read 2535 times)
dansmith180
Airbag fault
« on: November 30, 2014, 02:32:30 am »
My airbag light has been on for months, this is the code vagcom gave me anybody had this before?
01217 drivers side airbag igniter m199
Offline Dalejones
Re: Airbag fault
« Reply #1 on: December 01, 2014, 10:34:42 am »
Take the drivers seat out flip it upside down you will see a yellow plug, you need to cut the plug out and rejoin the wires, the plug is a common fault! Easy fix
Offline skard
  • -Receive: 245
Re: Airbag fault
« Reply #2 on: December 01, 2014, 12:02:45 pm »
dansmith180
Re: Airbag fault
« Reply #3 on: December 01, 2014, 01:35:29 pm »
See http://www.mk5golfgti.co.uk/forum/index.php/topic,39137.msg464177.html#msg464177 as there is a link to the repair also
Thanks very much guys, I did search but couldn't find anything. I was worked it could be an expensive issue, my car is 3dr and 2005 so chances are this will sort mine out. Thanks again  :happy2:
