Author Topic: Which Steering Controller Can I Use?  (Read 2037 times)
Offline SkyJawa
« on: December 03, 2014, 06:38:01 pm »
Just bought bbfb10's GTI Highline clocks.  Currently got midline with cruise.  What versions of the steering controller should I be on the lookout for so it all works properly?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which Steering Controller Can I Use?
« Reply #1 on: December 03, 2014, 07:24:28 pm »
Do u have a mfsw?
Offline SkyJawa
« Reply #2 on: December 03, 2014, 09:11:17 pm »
No, just a standard flat bottom, no paddles either, though would like the option to add one too......
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #3 on: December 03, 2014, 09:21:08 pm »
There You have the list of all controllers.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
CH will be the best option if you decide upgrade to MK6 MFSW.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: December 03, 2014, 10:06:24 pm »
For now you wouldnt need one, but when you do add a mfsw then get a CH controller and change them both at the same time.
Offline SkyJawa
« Reply #5 on: December 04, 2014, 07:36:24 am »
Ah ok cool, thanks guys that's brill :)
Offline SkyJawa
« Reply #6 on: December 11, 2014, 09:33:47 am »
Picked up a MKV mfsw with paddles, so I need to get the controller, but will I also need a new slipring?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #7 on: December 11, 2014, 09:51:18 am »
It depends which slip ring you have now. A quick way to tell is to scan with vcds and determine you existing steering wheel controller part number.
Use the Ross tech link above to see which slip ring that controller uses.
The CH controller uses a type 2 slip ring.
Jas
VCDS (Preston, Lancashire)
Offline SkyJawa
« Reply #8 on: December 11, 2014, 10:05:46 am »
Thanks Jas.  Also think I'll be needing the airbag harness so I can reuse the existing airbag so I need to get that too.  I believe the part is 1K0 971 584 L??
Edit scratch that - found out I need the C revision.
« Last Edit: December 11, 2014, 11:42:20 am by SkyJawa »
Offline SkyJawa
« Reply #9 on: December 11, 2014, 10:36:56 am »
Cool, mines a 1K0-953-549-F so its already a Type 2 so CH should be plug and play  :smiley:
