Author Topic: Camshaft positioner slow response  (Read 3535 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« on: December 04, 2014, 11:21:06 pm »
I had this code today following a scan. Does anyone know if I might be having early low oil pressure symptoms due to pickup pipe blockage, or is it more likely the n205 at fault?
P000A/000010 - Camshaft A (Bank 1 Intake): Positioner Slow Response
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Wiring/Connectors from/to Camshaft Adjustment Valve 1 (N205) faulty
Intake Camshaft Adjustment (Bank 1) faulty
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Perform Output Test
Check Wiring/Connectors from/to Camshaft Adjustment Valve 1 (N205)
Check Intake Camshaft Adjustment (Bank 1)
Perform Basic Setting
Check for Tightness of the Adjustment Mechanism
Check Engine Oil Pressure
'07 Red manual
Offline Carl123
Re: Camshaft positioner slow response
« Reply #1 on: December 07, 2014, 09:03:26 am »
I also have this code but mine only happened after cambelt waterpump chain and tensioner was replaced also replaced the N205 still have the code....mine maybe a slightly different problem as my N205 sensor has a tapping noise coming from it did some research few ppl say oil and filter change will stop this but I'm not 100%
