Author Topic: Wheel sealant recommendations  (Read 3934 times)
Offline Matto
  • -Receive: 116
« on: December 10, 2014, 01:30:53 am »
As per title. What do you use and recommend? I've Just had my winters refurbed so would like to give them a coat of something to protect them  :happy2:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Wheel sealant recommendations
« Reply #1 on: December 10, 2014, 08:51:47 am »
While I was sealing my car I though what would be the harm using the same stuff on the wheels so I used jetseal109 followed by autoglym super HD wax.
Cleaning is much easier and brake dust never sticks now!
Offline xjay1337
  • -Receive: 377
« Reply #2 on: December 10, 2014, 09:54:49 am »
FK1000p is good as it's high temperature so designed to deal with higher temperatures that SOME waxes cannot deal with.
Usually you can actually use any wax on the wheels, anything is better than nothing...
However anything wheels would recommend going with a ceramic/silica based coating. Cquartz UK or Car Pro DLUX I would personally recommend. Other similar coatings are available also.
Offline xjay1337
  • -Receive: 377
« Reply #3 on: December 10, 2014, 04:24:45 pm »
wax not tyre dressing :signLOL: :stupid:
Offline Matto
  • -Receive: 116
« Reply #4 on: December 10, 2014, 04:54:52 pm »
Cheers for that. Will have a look into them  :happy2:
Stevie35
« Reply #5 on: December 11, 2014, 12:45:08 am »
Try G-techniq. Brilliant stuff and last for ages to. Takes a bit of time n prep work to get them spotlessly clean but once its on, no dramas.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: December 11, 2014, 08:18:27 am »
Which G-Techniq is for wheels?
I find that range is a bitch to get my hands on in Ireland!
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: December 14, 2014, 02:38:02 pm »
Fk1000p is great. The tin is cool too.
'07 Red manual
Offline Horatio
  • -Receive: 39
« Reply #8 on: December 14, 2014, 10:54:03 pm »
PoorBoys wheel sealent for the smell alone
Offline DMcG
« Reply #9 on: December 15, 2014, 09:54:19 am »
+1 for FK lasts ages!
Offline cicco
« Reply #10 on: December 18, 2014, 04:58:49 pm »
I've always used poor boys, gives a great finish, and when u come to wash the wheels next time the dirt comes of easier
Offline xjay1337
  • -Receive: 377
« Reply #11 on: December 18, 2014, 05:08:52 pm »
Poor boys doesn't last well. much better out there for the money
Offline Frenzy
  • -Receive: 29
« Reply #12 on: December 21, 2014, 10:09:33 pm »
I agree that poor boys wheel sealant has a great smell but i have to agree more strongly with the point that it doesn't last long enough. When i finish my pot of poor boys i'll be getting something else, sounds like that something will be FK1000p  :smiley:
Offline BlueSmokeyJoe
« Reply #13 on: December 24, 2014, 12:48:53 am »
Wheel wise, the proper way to protect them is with a ceramic coating. G-Techniq C5 wheel armour is the product you will want.
If you have just had your wheels refurbed, excellent! As this will mean that they don't require a full decon/clean up. An IPA/panel wipe, wipe down is all they will need to ensure that the surface is free from any residue/grease etc, which will allow the solution to cure properly and form the most amount of bonds.
Application itself is just wiping over the wheels surface with the application pads, gently buffing off the excess product immediately after coating the whole wheel. For the next 12hrs, they will need to be kept dry and some where 'warm' to ensure they fully cure.
Once all that is done, your wheels will be covered with an extremely durable ceramic coating that will resist brake dust/dirt with better effect than other sealants that have been mentioned. Should give around 2yrs of protection and only require cleaning with mild solutions, even just regular car shampoo
Stevie35
« Reply #14 on: December 30, 2014, 09:47:08 pm »
What he said :happy2:
