Author Topic: Swapping Axx engine with bwa  (Read 9590 times)
Offline Jkingti
  • Ireland Dublin mk5 gti
« on: December 10, 2014, 01:57:24 am »
Hi guys I'm thinking of putting bwa engine into me 05 mk5 Gti me original engine code is Axx will the bwa work??
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Swapping Axx engine with bwa
« Reply #1 on: December 10, 2014, 05:29:28 am »
yes, without any issues, straight swap  :happy2:
Over the top mod list ;o)
Offline Jkingti
« Reply #2 on: December 10, 2014, 09:49:22 am »
Do I need to change ecu or anything? So the bwa definitely goes in and I won't have any problem trying to get it starting? Do I not need loom ecu or anything considering it is a diff engine code? Have you done this before? Thanks for your reply
  • -Given: 243
  • -Receive: 154
« Reply #3 on: December 10, 2014, 08:36:47 pm »
Only difference is the compression ratio, so no need to change anything but the engine.
I am running a cupra 245bhp BWJ engine in my AXX GTI with AXX ECU, to establish my credentials
Offline Jkingti
« Reply #4 on: December 10, 2014, 09:57:49 pm »
That's great thanks for your help! Do I need to swap anything from my Axx engine into the bwa as in injectors or anything? Can u send your email address as it would be great if I could get some more info from you. Thanks very much
  • -Given: 243
  • -Receive: 154
« Reply #5 on: December 11, 2014, 08:14:18 pm »
all but compression ratio is the same
Offline Jkingti
« Reply #6 on: December 11, 2014, 08:40:58 pm »
Do I need to change crank sensor from my engine map sensor or anythin or just plug and play? I've heard I need to change fuel lines as the lines to my hpfp one is a banjo bolt and on the bwa engine the fuel line to hpfp is a hose
  • -Given: 243
  • -Receive: 154
« Reply #7 on: December 12, 2014, 05:04:55 am »
No
Offline Jkingti
« Reply #8 on: December 13, 2014, 01:16:27 am »
hpfp is diff
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: December 13, 2014, 08:42:51 pm »
hpfp is diff
Use your old HPFP if you like, only the connector is different then (banjo instead of later connection). The rest of it - mounting, piston, outlet & capability are all the same  :happy2:
Offline Jkingti
« Reply #10 on: December 13, 2014, 09:47:46 pm »
Is all wiring the same also the same? I have sourced a bwa engine but the lad said some wiring may have to be relocated? Is this true? Thanks for your reply much appreciated
Offline muff1991
  • -Receive: 69
« Reply #11 on: December 17, 2014, 04:53:22 pm »
can I ask why you want to change to the BWA ?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: December 17, 2014, 04:55:02 pm »
Less susceptible to cam chain and cam follower problems
Offline muff1991
  • -Receive: 69
« Reply #13 on: December 17, 2014, 04:56:13 pm »
I thought they was all the same though? apart from compression rating
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #14 on: December 17, 2014, 04:57:21 pm »
Different cam, different Pistons, probably some other tweaks elsewhere. . .
Different engine code signifies differences. .
