Author Topic: Fitting mfsw?  (Read 3985 times)
Offline mk4gti-t
  • -Given: 61
Fitting mfsw?
« on: December 10, 2014, 11:18:30 pm »
Do I need anything else in order to fit a mfsw to my 2005 gti DSG? I currently have a flat bottom gti wheel without paddles and highline display. Cheers
Offline Callum45
Re: Fitting mfsw?
« Reply #1 on: December 10, 2014, 11:27:42 pm »
You will need a new steering wheel control module as well.
Offline GTi-Andy
Fitting mfsw?
« Reply #2 on: December 11, 2014, 03:01:33 am »
Have you seen my advert in the for sale section?
Sorry, thought you were looking to buy!
So much for keeping it standard!
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #3 on: December 11, 2014, 07:21:55 am »
Any particular revision of controller?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Fitting mfsw?
« Reply #4 on: December 11, 2014, 07:26:24 am »
CH version
VCDS (Preston, Lancashire)
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #5 on: December 11, 2014, 07:43:05 am »
Cheers  :happy2:
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #6 on: December 11, 2014, 07:50:03 am »
Is this part number correct -1K0953549CH
Jesus if this is the one I need these bloody expensive  :surprised:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Fitting mfsw?
« Reply #7 on: December 11, 2014, 08:47:33 am »
thats the one,
http://www.ebay.co.uk/itm/OEM-MF-Steering-Wheel-MFSW-Module-For-VW-Jetta-Tiguan-Golf-GTI-6-MK6-1K0953549CH-/321428386324?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ad69ff214
me and a few others have bought from here.
If you need a guide on how to fit it all, heres a video I made
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #8 on: December 11, 2014, 08:52:25 am »
Thanks for the link. Are these chinese units decent quality? Also will I be able to fit dsg paddles to this?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Fitting mfsw?
« Reply #9 on: December 11, 2014, 09:05:25 am »
Yes i have fitted DSG MFSW and works perfectly fine. Just make sure you have VCDS to code the control module.
If you do a bit of searching, you will find that they are produced by FAW who make parts for VW asian market.
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #10 on: December 11, 2014, 09:17:54 am »
Thanks again. I'm looking at a mfsw from a 2009 manual car and want to fit a pair of genuine paddles to it. Hopefully the wheel will be ok for this?
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #11 on: December 11, 2014, 09:10:54 pm »
Hello again, more questions........ Will I need to replace the slip ring and airbag harness? Also what needs coding in vcds? Cheers.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Fitting mfsw?
« Reply #12 on: December 11, 2014, 11:47:26 pm »
I posted this in another thread earlier...
It depends which slip ring you have now. A quick way to tell is to scan with vcds and determine you existing steering wheel controller part number.
Use the Ross tech link above to see which slip ring that controller uses.
The CH controller uses a type 2 slip ring.
Jas
You will probably need to change the airbag harness too. I did when I did mine.
Jas
Offline skard
  • -Receive: 245
Re: Fitting mfsw?
« Reply #13 on: December 11, 2014, 11:56:44 pm »
You don't need a CH controller to use a mk5 MFSW, that's for putting a mk6 wheel on a mk5
Offline mk4gti-t
  • -Given: 61
Re: Fitting mfsw?
« Reply #14 on: December 12, 2014, 06:58:35 am »
Oh dear...... Anybody want a ch controller? What exactly will I need then?
