Author Topic: Shell Helix Ultra- 5w-40 Fully Synthetic- can we use this?  (Read 5386 times)
Offline Homer
« on: December 14, 2014, 12:44:56 pm »
So my dad took the car out- oil light came on and he filled it with the above oil... Is this engine oil okay to use or should I opt for an oil change? The GTI does have a thirst for engine oil and I usually have to top up regularly. I was thinking to leave it until it needs more oil and then top up using my normal oil. What's the thoughts on the forum? Thanks
dansmith180
Re: Shell Helix Ultra- 5w-40 Fully Synthetic- can we use this?
« Reply #1 on: December 14, 2014, 01:14:31 pm »
It depends what's in there ATM, that oil is fine as long as what's in there now is also 5w40 fully synthetic.
Offline ruhaleali
« Reply #2 on: December 14, 2014, 01:24:08 pm »
This can differ, as mine is Stage 1 and doesn't ask for too much oil. The 5w-40 is thicker and is recommended when having a remap done. I recommend using this as It makes a better difference from the 5w-30. You should be fine!
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: December 14, 2014, 01:43:22 pm »
I use Shell Helix 5w-40 as it's more tolerant to higher engine temperatures, normally associated with re-mapped/tuned engines. In an ideal world, you should never mix oils, but as long at you keep the first bit (5w) the same you shouldn't have any issues.
Advice: Do a good oil service next time it's due, make sure you let it drain as much as possible and clean all the filter housing thoroughly. :happy2:
Offline Frodo-anni
  • -Receive: 45
« Reply #4 on: December 14, 2014, 08:00:48 pm »
My local main dealer, has joined the sytner group and has started using Shell oil.
mk5 GTI Edition 30 DSG No0391
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #5 on: December 15, 2014, 07:43:18 am »
The oils can be mixed without issue, although I would be worried if the oil pressure warning came on whilst driving the car. Either you have a pump/pickup problem or you've let the car get indcredibly low on oil
Stick with a good quality 5w40 oil and you'll be alright. Checking the level once a week or once every couple of weeks doesn't take long :happy2:
