Author Topic: 1K0 907 530 L can gateway but what versions of RNS/RCD 310/510 will work ?  (Read 9108 times)
Offline pjuster
Hi,
I have the following can gateway in my new (2nd hand) GTI,
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 070807F2000490
   Coding: E9807F0E0002020003
   Shop #: WSC 01279 785 00200
   VCID: 306FF64BA3D6889E243-8065
I've yet to decide on a 310 or 510 or even a RNS or RCD (budget allowing) but can anyone advise if I need to ensure a specific version of any of these models to a avoid battery drain or b avoid any other problems.
thanks in advance
Paul
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: 1K0 907 530 L can gateway but what versions of RNS/RCD 310/510 will work ?
« Reply #1 on: December 15, 2014, 09:55:38 pm »
Your good to go Paul, I have an "L" version gateway and have fitted a version "C" RNS 510 previously and now have a "R" with no problems  :happy2:
Offline pjuster
« Reply #2 on: December 15, 2014, 09:56:47 pm »
cool, may I ask the difference between a version C and R ? is there a list of the versions and the changes or do I just need to keep googling?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: December 15, 2014, 10:01:12 pm »
There's two "C" versions, there was a cross over from an lcd screen to Led.
Small improvements to screen quality, processor speeds and large storage space from what I can remember up through the different revisions, not sure if there's a list mate too be honest
Offline pjuster
« Reply #4 on: December 15, 2014, 10:09:23 pm »
ok great thanks for the information.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: December 16, 2014, 12:33:16 pm »
You just needed to check this list: http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
Yours isn't listed so you're good to go. :happy2:
Offline pjuster
« Reply #6 on: December 17, 2014, 12:06:04 pm »
sorry, thanks  :happy2:
Offline bad devotions
  • -Given: 19
« Reply #7 on: December 19, 2014, 08:36:40 am »
how can you tell what version is installed? I have a sep 06 GTI and want to upgrade my RCD300 to either a RCD310 or 510.
Offline pjuster
« Reply #8 on: December 19, 2014, 08:41:37 am »
you can either pyhsically look at the can bus gateway (see the guides on how to do this), or you can scan your car with a vag-com lead/software and that will tell you the h/w number.
I fear your car is maybe too old and you will need to replace it with an updated can bus which would need recoding, eddie-nl on here or others on ebay can supply this and you have to fit it.
HTH
Paul
  • -Given: 19
« Reply #9 on: December 19, 2014, 08:55:15 am »
Thanks Paul - I am just starting on this upgrade journey so have a bit to learn. Trying to find guides on it at the moment, but not having a great deal of success. As far as i can tell the CAN gateway is a little black box located somewhere on the car. Ideally the part number needs to be 1K0 907 530 L as this will allow the 310/510 to be installed without the battery drain issue. So far so good?
Offline pjuster
« Reply #10 on: December 19, 2014, 09:00:04 am »
 You just need to check this list:http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting  for which can bus gateways don't cause the drain
 its not only the L version, as for where the can bus might be check out  http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543 it gives a great guide and links to other sites, on where the can bus might be, depending on the age of the car.
 I found a big clue is look for the "red plug", that seems to be the common thing across all models and its the plug into the can bus, but it is tucked away.
my 57reg was behind the relay carrier which can be access from inside the car or more easily from the windscreen/engine bay
HTH
Paul
« Last Edit: December 19, 2014, 09:25:41 am by pjuster »
Offline skard
  • -Receive: 245
« Reply #11 on: December 19, 2014, 09:44:19 am »
An 06 GTI will not have come with an L or above, unless an ex owner has swapped it out.
The very last release of a K version doesn't have battery drain, you may have a K. Still you either need to take a pic of the sticker or get a VCDS scan to see the software revision on it.
  • -Given: 19
« Reply #12 on: December 19, 2014, 02:58:42 pm »
Thanks for the info guys. I'll have to take a look when it's not bloody raining and i can get outside for more than 5 minutes! :D Don't have VCDS so it's going to be a case of looking at the sticker.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: December 19, 2014, 03:04:39 pm »
If you need a gateway send me a PM
I can offer new pre-coded, supply and fit or I could flash your old one so you don't have battery drain
Cluster and Key coding
Location Great Yarmouth
  • -Given: 19
« Reply #14 on: December 20, 2014, 07:05:14 pm »
Hello,
I managed to get an auto electics place to run a quick scan (not Vag Com) and I found out the following:
unit code___1K0907530H J533_Gateway H12
Software status 0150
I am guessing that this gateway is too old to fit a newer style head unit without battery drain
@Eddie-NL can you let me know how much a can will cost? Many thanks!
