Author Topic: How to remove rear dome light cage?  (Read 1155 times)
Offline K9
  • VW LifeStyle
« on: December 15, 2014, 10:05:41 pm »
how do i take the whole rear interior light dome cage out from the look? asap help please
Re: How to remove rear dome light cage?
« Reply #1 on: December 16, 2014, 02:29:05 am »
are you changin the bulbs
Offline K9
  • VW LifeStyle
« Reply #2 on: December 16, 2014, 08:38:57 am »
yes but need to take it down becouse the pins inside where the bulb comes are to wire and i need to take it out and push them together again so the bulb fitts tight
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #3 on: December 16, 2014, 08:54:04 am »
There is two clip tabs to press and it will then flip down one side lift out and disconnect wiring
Offline K9
  • VW LifeStyle
« Reply #4 on: December 16, 2014, 04:19:12 pm »
ok seems simple enough, will try on friday after work in the garage  :driver:
Offline Golf_GT_TDI
  • -Given: 45
« Reply #5 on: December 16, 2014, 05:26:01 pm »
sorry.. to be more clear it after releasing the tabs it should come down on the side the tabs are (front or rear can't remember which) and lift out from the other side  :happy2:
