Author Topic: Tick over misfire?  (Read 1748 times)
Offline mk4gti-t
  • -Given: 61
Tick over misfire?
« on: December 16, 2014, 10:10:05 am »
When at a standstill in N my 2005 gti dsg will 'pop' occasionally while ticking over. If I knock it into D with my foot on the brake it ticks over fine..... Any ideas? Checked the usual pcv and all seems OK?
Offline john87
  • -Receive: 53
Re: Tick over misfire?
« Reply #1 on: December 16, 2014, 12:17:30 pm »
possibly spark plug(s) need cleaned/replaced?
I would have said coil pack is maybe on its way out, but these usually show a misfire under load, as opposed to when idling.
A scan with VCDS may highlight a misfire
Offline Carl123
« Reply #2 on: December 16, 2014, 02:03:59 pm »
Had mine scanned yesterday I have misfire on cylinder 2 on idle but when under load etc it's fine misfire disappears gonna change plugs before coil pack!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: December 16, 2014, 06:46:17 pm »
Very common on these. Either dirty valves & intake tract or an injector failing  :sad1:
Offline mk4gti-t
  • -Given: 61
« Reply #4 on: December 17, 2014, 07:46:04 am »
Whats the best way of cleaning the intake system and valves? Are we talking a head off job?  :sad1:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: December 17, 2014, 07:47:40 am »
Inlet manifold off and manual cleaning. Plenty of DIY guides on other forums. It takes a long time as the carbon is hard baked on
Offline mk4gti-t
  • -Given: 61
« Reply #6 on: December 17, 2014, 08:01:43 am »
Thanks mate, gives me something to do over the holidays  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 19, 2015, 01:37:54 pm »
Idle control valve was faulty on the one I was buying from a garage and they had already diagnosed the fault to the idle control valve which now been replaced and idling fine. Something to thing about along with plugs coils packs etc.
