Author Topic: Flat spot at 5200rpm on 2.0T - Does yours do it?  (Read 83009 times)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: Flat spot at 5200rpm on 2.0T - Does yours do it?
« Reply #195 on: March 14, 2010, 02:18:31 pm »
We are getting better slightly.
B8 t6 f9 pulls hard. Still a flat spot but not as noticeable
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #196 on: March 14, 2010, 04:03:12 pm »
Video of a k04 car with flat spot.
Its gone from b7 timing 5 fuel 7 to boost 8 timing 6 fuel 9 and seems to run much better.
Anyway compare the two vids and come up with your own conclusion.
http://www.youtube.com/watch?v=jfDc-OEzhgE b7 timing 5 fuel 7
http://www.youtube.com/watch?v=ZFLVP-dDWyE b8 timing 6 fuel 9
Offline NEWEY
    • Flickr
« Reply #197 on: April 03, 2010, 09:53:40 pm »
Just to let you all know my sports cat was replaced on Thursday. Everything is sorted at the flatspot has gone. Milltek have actually stopped doing two different size down pipes k03/k04 they now just do the 77mm which I beleive is the one they used on the k04.
TSR big turbo mk5 golf gti
Offline david_phillips95
« Reply #198 on: April 04, 2010, 12:53:34 am »
i have ordered up the RS4 fuel pressure regulating valve to see if i can get rid of the flat spot on B9 setting. The OEM valve limits the pressure to 130bar vs the RS4 valve that limits the pressure to 136bar. Near redline i have seen requested fuel rail pressure at 132bar but the actual rail pressure never goes much above 130bar then drops to about 127bar and builds back up to 130bar..therefore the OEM valve must be doing its job and opening and closing to stop the pressure exceeding 130bar. With the RS4 valve im expecting the requested fuel rail pressure to be met as the valve will stay closed up to 136bar. if there is a pressure surge it will still protect the fuel rail and open to release any pressure above 136bar. Ill keep you guys updated.
The valve in ETKA:
« Reply #199 on: April 04, 2010, 11:22:44 am »
That valve looks like a b*tch to install if you don't remove the intake manifold...
Offline cupra_k1
« Reply #200 on: April 04, 2010, 12:13:26 pm »
I have fitted the RS4 valve to my car. It was a bit of pig to fit without removing the inlet manifold. I found sleeving a piece of 5/8 hose over the valve to spin it undone and removing it made light work of it though. I've not yet had chance to drive it hard enough to see if it has cured the dreaded flat spot but the car deffinately feels smoother and more responsive.
« Last Edit: April 04, 2010, 12:15:26 pm by cupra_k1 »
Offline djhorace
« Reply #201 on: April 04, 2010, 03:10:19 pm »
It has been done on my car too.
This is the valve that came out.
Unfortunately I havent had the chance to run mine properly yet either.
« Reply #202 on: April 04, 2010, 03:16:45 pm »
I'm now running B7 T5 F9 and the car runs like an S.O.B. :laugh: :evilgrin:
I have had the RS4 valve fitted for a few months now and have also had the Forge K04 actuator fitted.
The Actuator took a fair bit of setting up, but now it is settled in it runs just great.
The RS4 valve ensures that the actual meets requested. Like others have already said, my car failed to meet requested between 0 and 5 bar, which could give issues with how the car runs (although I haven't felt anything).
The side effect of fitting the valve is that it helps with the low pressure in-tank pump. I found during logging that before the RS4 valve was fitted my in-tank pressure was dropping down to 3.5bar, which would affect it's ability to back up the high pressure rail system. Now the valve is fitted it doesn't drop below 3.9, so it has the ability to back-up the rail system faster. :smiley:
Offline djhorace
« Reply #203 on: April 04, 2010, 03:28:01 pm »
John - Did you get my text about setting up my car for Steve mate?
Offline robern2
« Reply #204 on: April 04, 2010, 04:48:56 pm »
Hurdy,
isn't your boost 7 the equivalent of boost 9 due to your actuator fiddling ?
« Reply #205 on: April 04, 2010, 04:59:21 pm »
Yeah :happy2:
I'll be down Tuesday afternoon to sort it :smiley:
Offline RobH
  • Revo stg 2+
« Reply #206 on: April 04, 2010, 05:01:30 pm »
Are you still down south getting your car sorted.
« Reply #207 on: April 04, 2010, 05:04:42 pm »
Hurdy,
Yup :happy2:
Before the actuator I'd been using B9 T6 F6 and B9 T7 F9 & F6 (when trialling octane booster :evilgrin:)
Both worked fine :smiley:
« Reply #208 on: April 04, 2010, 05:05:55 pm »
His car is here, but he's back home.
Offline djhorace
« Reply #209 on: April 04, 2010, 05:43:28 pm »
Thanks bud. It will have an Evoms on it, so I am guessing Boost 9 Timing 6 Fuel 6 maybe? Bummed I wont be there to take it for its first blast with the Wavetrac, but I am sure it will be down the drag strip before I get back :pomppomp:
