Author Topic: Is my clutch on the way out?  (Read 2854 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: December 18, 2014, 02:24:07 pm »
I fear my clutch or connected part is on the way out.
On hill starts there's a bit of a squeal and the same when I have the car in too high a gear and try pull away.
It sounds like a bearing squeal.
The clutch is holding throughout all gears and revs and never misses a beat if I put the foot down.
Clutch or clutch bearing?
Anyone experience this and have a rough cost for a new one?
Stock gti and no intention to go uprated from oem!
Offline howie1987
  • -Given: 92
  • -Receive: 20
Re: Is my clutch on the way out?
« Reply #1 on: December 18, 2014, 05:09:05 pm »
Could be the slave cylinder?
If its your clutch you should be able to smell it.
Offline Williams
« Reply #2 on: December 18, 2014, 05:13:12 pm »
I just had mine done clutch flywheel and slave done by vw at a cost of £1321 ouch.
Offline xjay1337
  • -Receive: 377
« Reply #3 on: December 18, 2014, 05:33:33 pm »
Lol you got screwed over I'm afraid
An uprated Helix clutch with new DMF is £750-odd and installation is about 4 hours labour. I'm expecting to pay around £950 fitted for my Paddle clutch and my mate is having the Helix clutch i mentioned with new flywheel for £950-ish at @ AKS Tuning
OP: Doesn't sound like your clutch. Probably a slipping belt (auxiliary) causing the noise.....
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: December 18, 2014, 09:41:00 pm »
 :ashamed:
As Jay said. Massively overpaid there. Just shows how much of a rip off VW are for maintenance
Offline mvb12
  • -Receive: 64
« Reply #5 on: December 18, 2014, 10:50:24 pm »
 :ashamed:
yes that's overpriced, the joys of the stealers  :jumping:
Offline Williams
« Reply #6 on: December 19, 2014, 07:48:45 am »
Lesson learned will do lot more looking around first in future.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: December 19, 2014, 09:00:44 am »
Slipping belt? Any thoughts where to start. I've diy's pretty much everything to date so I'll have a go myself before the garage get at it. Just need to know where to start! Thank you!
Offline muff1991
  • -Receive: 69
« Reply #8 on: December 20, 2014, 12:31:33 am »
when does it make the squealing noise? does it do it from cold?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #9 on: December 20, 2014, 11:01:20 am »
Happens on cold and hot. Only when doing a hill start or of if I've engaged too high a gear i.e. when the clutch is under more pressure
Offline xjay1337
  • -Receive: 377
« Reply #10 on: December 21, 2014, 03:59:17 pm »
Happens when the engine is under load (IE pulling away).
Won't be the clutch it will be timing or auxiallary belt probably a tensioner.
Kam88
« Reply #11 on: December 21, 2014, 05:59:30 pm »
Asked vw how much for changing spark plugs oil filter oil air filter and I will supply all the parts they said £210 NOT THANKS !
