Author Topic: GTi Dsg fuel economy poor!  (Read 9638 times)
Offline nik nak
« on: December 18, 2014, 10:26:19 pm »
Hi i have had my Gti Dsg for few months and  has 101k on the clock but im struggling to get good mpg from it it struggles to get to 25mpg and thats taking it easy!,
I have removed the pre Cat
I have changed the Dv for a G version as my original one was torn
Changed the pcv for N version
Changed Fuel filter
Cleaned the Maf sensor , Intake temp and Map sensor.
Checked spark plugs and Air filter.
Swaped N80 valve for a Known working one.
Swaped before Cat lambda sensor for a Known working one.
There are no codes in Vcds
Im a bit stumped any help apreciated Thanks :happy2:
« Last Edit: December 18, 2014, 10:28:27 pm by nik nak »
Offline mvb12
  • -Receive: 64
Re: GTi Dsg fuel economy poor!
« Reply #1 on: December 18, 2014, 10:47:56 pm »
few diesels for sale mate.
always find these MPG threads funny.  :ashamed:
Offline nik nak
« Reply #2 on: December 18, 2014, 11:01:35 pm »
lol Looking at other 2.0 tfsi owners they are getting 30-40 mpg out of the 2.0 tfsi which makes me think mine is no where near?
Offline jamie
« Reply #3 on: December 18, 2014, 11:12:32 pm »
What grade petrol are you using?
Check tyre pressures too?
Offline nik nak
« Reply #4 on: December 18, 2014, 11:15:12 pm »
I have been using tesco 99 and i did check the tyre pressures were ok.
Offline sanj
  • -Given: 17
« Reply #5 on: December 18, 2014, 11:36:27 pm »
25 mpg seem's about right at this time of the year when it's quite cold,I get around 20mpg but I am in a DSG MK6 R!Only seen 30mpg+ in the summer.
Offline nik nak
« Reply #6 on: December 18, 2014, 11:39:09 pm »
It does not really reach 25mpg unless i drive really carefully , i am getting about 280miles to a full tank.
Offline dan930
  • -Receive: 56
« Reply #7 on: December 19, 2014, 12:24:28 am »
Best I got on my R is 30mpg during this time of year...
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Matthewsimone
  • -Receive: 39
« Reply #8 on: December 19, 2014, 07:14:38 am »
To be fair mate 280 miles from a tank isn't that far off really! Best im seeing is 310-320 miles to a tank on a 51 litre fill up which is working out at about 28.5mpg average and yours works out at 24.5mpg
I do alot of short journeys so all my fuel gets burned away on the warm up process for a 6 mile journey to work etc although if i do a bit of a run and set cruise to 65mph can achieve 42mpg (standard 2007 Gti 69k miles)
Do also remember that Dsg is apparently a little worse on fuel compared to my manual according to factory figures!
Im lucky enough to have best of both worlds as the wife gas a 2008 Gt tdi 140 which returns around 550 miles on a tank  :laugh:
Mine is for pleasure hers is the mile eater
As good as the Gt is she still much prefers the Gti to drive, so smooth in comparison and heaters dont take an age to get warm like they do in the diesel
What made you change the maf as they very rarely go wrong on the Gti and not a cheap item to replace for a genuine Vw item?
dansmith180
« Reply #9 on: December 19, 2014, 08:13:08 am »
My average ATM is about 22mpg and in the summer its about 25mpg. Fuel prices are plummeting now so it's not something to worry about tbh. I thought mine maybe had an issue because of the mpg but then I remembered its a performance car and you've got to feed the ponies  :laugh:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=gkn7n0hb2ne5af003m879lqpcg&/topic,19740.0.html
« Reply #10 on: December 19, 2014, 08:17:41 am »
Are we talking 280miles of motorway bashing or city "stop start""
On a run up the m'way you should be able to get 30 easy enough sat at 70-80.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #11 on: December 19, 2014, 08:39:12 am »
^^^ Exactly. 30-35mpg on the motorway is what I get.
I'd say yours has a problem. Do you keep the boot full of stuff?
'07 Red manual
Offline kth286
« Reply #12 on: December 19, 2014, 08:45:51 am »
Brakes sticking slightly ON can make a big difference to mpg - including the hand brake.
A clue can be the wheel with most brake dust on it.
Also will the car easily roll down even the slightest slope ?
Offline mac456
« Reply #13 on: December 19, 2014, 10:29:01 am »
Sounds normal for a city run.
On the motorway around 30 is what I get.
Offline SiofChester
« Reply #14 on: December 19, 2014, 11:09:26 am »
Sorry folks, I hate it when people do this, but I get 35mpg every day on my commute (A road country lanes, not motorway) and on a sensible 20 mile run this week, got the right side of 40mpg. Best EVER way nearly 50 on a very long run at 60mph.... If you're not seeing at least 30mpg, something is wrong....
