Hi All,
Ive fitted a reverse camera today, Red wire to 12v live, Black cable to ground yellow wire to reverse trigger. Connected the long coaxial cable to back of rns, programmed using VCDS, reboot rns, closed all doors and the boot, put in reverse, Camera flips out but nothing on the display.
Tried another coaxial cable but still the same. Checked voltage on the yellow wire at the badge end and theres 12v when in reverse.
What could be the problem?
I did the exact same setup on my old golf last year and that worked fine. Only thing different on this setup is I have an old canbus and firmware 3810 modified .
Any suggestions would be really appreciated
