November 24, 2024, 11:13:53 am
All Things Mk5
How to Guides / Troubleshooting
Help with battery change
Topic: Help with battery change (Read 4038 times)
Woody79
Can't Read PM's Yet!
-Given: 5
-Receive: 0
December 22, 2014, 03:17:49 pm »
Hi just wondering if anyone can point me in the direction (if there is one) of s guide to changing the battery. Old one has had it and have purchase a bosch s4 to put in.
Can anyone help me please I'm a bit of a novice at DIY car stuff !
Cheers and merry Xmas
SiofChester
Always Involved
-Given: 16
-Receive: 6
Re: Help with battery change
Reply #1 on:
December 22, 2014, 03:19:42 pm »
Very little to it, just make sure you disconnect the negative terminal FIRST, then when the new battery is in, connect the positive first and the negative last. Give it a go, it's very easy!
rich83
Just look at my post count
-Given: 165
-Receive: 802
My Ride:
Reply #2 on:
December 22, 2014, 03:53:08 pm »
- terminal
+ terminal
Remove plastic shroud
13mm bolt to remove the clamp
Remove battery.
Reverse
https://www.justgiving.com/thenational3peaks
homesqueeze
Won't Shut up.
-Given: 32
-Receive: 43
Got another Golf!
Reply #3 on:
December 22, 2014, 04:17:42 pm »
Have your key fob handy as the alarm may go off as you disconnect and reconnect one of the terminals.
Woody79
-Given: 5
-Receive: 0
Reply #4 on:
December 22, 2014, 04:18:46 pm »
Great cheers for that will have s bash tomorrow .... 10 mm for terminals 13 mm for clamp - any other tools required for it? Am borrowing what I need
-Elliot-
Just Arrived
-Given: 1
-Receive: 0
Reply #5 on:
December 23, 2014, 10:53:28 pm »
Coating the terminals with grease helps keep away moisture too!
Andy
Admin
-Given: 39
-Receive: 443
Reply #6 on:
December 23, 2014, 11:31:46 pm »
Also their will be some lights on the dash when you start the engine..take the car fir a little drive and they should go of
gttdi build thread
r32 build thread
dan_the_v8man
Taking part
-Given: 0
-Receive: 0
Reply #7 on:
December 28, 2014, 09:30:36 pm »
12" extension to get to the battery clamp
All Things Mk5
