Author Topic: Today I have mostly been......  (Read 4778 times)
« on: November 19, 2009, 04:42:46 pm »
Messing around with this little lot :evilgrin:
New Denso Iridium power sparkplugs. Cooler rating than stock plugs and should help stop any misfires. :happy2:
http://www.densoiridium.com/ir_power.php
Millers CVL Turbo Octane booster :evilgrin: :evilgrin: :evilgrin:
http://www.millersoils.net/M3_cgi/millers2.cgi?product_id=157&exact_match=on&type=motorsport&cart_id=
Tested this on my original REVO stage 2+ settings of B9 T6 F9 and found it to perk up the top end nicely. I've since phoned REVO HQ who said to try B9 T7 F6 to get the most from it without pushing the car too far. The results are very good as seat of the pants difference feels very good throughout the rev range. I've booked back in to Nobles Dyno to see if it is just me or if it really is the settings and octane booster. :jumping:
Re: Today I have mostly been......
« Reply #1 on: November 19, 2009, 04:47:57 pm »
Offline DanGB
  • Different
« Reply #2 on: November 19, 2009, 04:51:55 pm »
I heard this was the best stuf so bought some, havent used it yet. Do some logs to see if the timing is advancing more and its not pulling back.
http://www.rogerclarkmotorsport.co.uk/shop_detail.asp?productID=196
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline animal
  • .:R32
« Reply #3 on: November 19, 2009, 04:53:07 pm »
Any actual VAGCOM logs to compare? Looks you've a more intersting day that I have.
Offline tony_danza
  • -Receive: 112
« Reply #4 on: November 19, 2009, 04:54:45 pm »
Interesting viewing...
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: November 19, 2009, 05:00:35 pm »
Dan iirc you have water meth injection. Does that not have the same effect as using octane booster to a certain degree.
Offline tony_danza
  • -Receive: 112
« Reply #6 on: November 19, 2009, 05:04:50 pm »
I will say about that Fifth Gear vid - there's a bit of difference in a bench K-Series and a turbo car with adjustable software.
Let us know how you get on Hurdy.  :happy2:
Sideways yo!
« Reply #7 on: November 19, 2009, 05:17:30 pm »
I suspect that it's just down to the settings...
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #8 on: November 19, 2009, 05:21:40 pm »
Hurdy, would have thought with your mods you would be running Boost 9 Timing 6 and fuel 6 on v power.
Then for higher octane than v-power you just advance timing
« Reply #9 on: November 19, 2009, 05:30:23 pm »
That looks interesting too. Looks like back to back testing for me over the next few weeks :evilgrin:
« Reply #10 on: November 19, 2009, 05:34:11 pm »
That's what I'll be doing from now. I've gone from b9t6f6 to b9t7f6 to try out the octane booster.
As Bacillus says, the timing difference will make the extra power, but it should be the octane booster that allows me to run t7 :smiley:
« Reply #11 on: November 19, 2009, 05:34:57 pm »
Oh and I have to do these before the end of next week as the DECAT section is going on  :evilgrin:
« Reply #12 on: November 19, 2009, 05:45:20 pm »
Increasing your fueling to F6 has the "side effect" of extra cooling the cylinder temperature thereby allowing higher timing to be used with less CF pull.   :smiley:
You don't want to increase the fueling too much or you'll end up with petrol dilution of the oil on your cylinder wall leading to increased rate of cylinder bore wear.
« Reply #13 on: November 19, 2009, 09:34:55 pm »
Yeah, they did mention that running F6 would help with keeping things cool. If the logs look okay I might push it back up to 7. :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: November 19, 2009, 09:56:43 pm »
hurdy how come you not interested in water methanol injection. ill act like octane booster(if not better)and clean all the inlet valves and reduce temps.
