Author Topic: RNS510 Noise?  (Read 2537 times)
Offline Munzz
RNS510 Noise?
« on: December 25, 2014, 06:18:56 pm »
Evening All,
I fitted my RNS today and all is well but I noticed that when the engine is off I can hear a slight buzzing noise from the unit itself; either the hard drive or cooling fan.
I have a new CAN Gateway so I hope this won't cause the battery drain issue but when I tried to start my car it did struggle, although managed to start.
Is this something to be concerned about or could it have just been a cold start issue and a coincidence!?
I've logged details of my unit below.
Thanks all, and Merry Christmas.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: RNS510 Noise?
« Reply #1 on: December 25, 2014, 06:32:09 pm »
What reg is the car? Making a noise is normal
Offline skard
  • -Receive: 245
Re: RNS510 Noise?
« Reply #2 on: December 25, 2014, 06:50:02 pm »
It has an Econ panel so I'd say 2006 or older, will suffer gateway drain in the interim unless it has previously been swapped out.
Offline Munzz
RNS510 Noise?
« Reply #3 on: December 25, 2014, 07:04:41 pm »
Hi,
I had a new gateway from Eddie installed to prevent drain. I'm hoping I start the car tomorrow fine, just concerned that something is active whilst the car is stationery and not live.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: RNS510 Noise?
« Reply #4 on: December 25, 2014, 07:13:14 pm »
The rns normally does stay on for a bit when the car is switched off,but eventually the unit will switch off completely.
Offline Munzz
Re: RNS510 Noise?
« Reply #5 on: December 25, 2014, 08:14:47 pm »
I'm pretty sure it lasted around 3 hours!
I'll soon find out if it's worth worrying about tomorrow.
Offline dan_the_v8man
Re: RNS510 Noise?
« Reply #6 on: December 28, 2014, 08:59:40 pm »
I seem to recall last time I changed the hard drive in these that they have a small cooling fan that runs on for a while after the ignition is off
Re: RNS510 Noise?
« Reply #7 on: December 28, 2014, 09:00:02 pm »
3 hours isn't right though
Offline mvb12
  • -Receive: 64
Re: RNS510 Noise?
« Reply #8 on: December 30, 2014, 08:46:20 am »
the fan normally stays on for around 5 mins max after ignition off. 3 hours isn't the norm.
Offline Munzz
Re: RNS510 Noise?
« Reply #9 on: December 30, 2014, 05:59:23 pm »
It's the faintest noise and can only be heard when you put your ear to the unit, seems I was getting ahead of myself with the OCD!
