Author Topic: OEM Bi-Xenon shutter stays ON!? FAST HELP NEEDED!!!!  (Read 3516 times)
Offline K9
  • VW LifeStyle
« on: December 26, 2014, 02:45:22 am »
Hey. Noticed today when i was driving at night that my both shutters stays on and the FTP bulbs working fine when switching over to highbeam. I washed the car today at a service station and it was -13 celcius outside. If that help any. What can i check to solve the shutter problem? Thanks you!
« Last Edit: December 26, 2014, 08:53:04 pm by K9 »
Offline K9
  • VW LifeStyle
Re: OEM Bi-Xenon shutter stays ON!?
« Reply #1 on: December 26, 2014, 01:23:03 pm »
Anyone? Cuz i cant drive becouse i'm blinding oncoming traffic :(
Offline K9
  • VW LifeStyle
Re: OEM Bi-Xenon shutter stays ON!? FAST HELP NEEDED!!!!
« Reply #2 on: December 27, 2014, 09:04:24 am »
Comeon guys?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #3 on: December 27, 2014, 09:54:26 am »
The shutters are normally controlled by the CECM which activates a solenoid in the head lamps.
I guess the solenoid is getting stuck or there is a wiring fault maybe?
VCDS (Preston, Lancashire)
Offline K9
  • VW LifeStyle
« Reply #4 on: December 27, 2014, 10:05:22 am »
how can i check the solenoid? cabels are good. i cut one shutter wire that goes to the CECM and still open. how can i be bringed down manualy?
@jason_rmh
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #5 on: December 27, 2014, 10:21:53 am »
They stay open even when ignition is off?
Try shaking / knocking the headlamp assembly, it may close the shutters. Although this is only a temporary fix as they will probably stick open again when used.
Is this happening on both headlamps?
Offline K9
  • VW LifeStyle
« Reply #6 on: December 27, 2014, 10:43:27 am »
yes they are open even when ignition is on and flashing the FTP as they are activated with shutter. both are open.
@jason_rmh
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #7 on: December 27, 2014, 11:32:40 am »
See this thread for for info:
http://www.golfmkv.com/forums/showthread.php?t=157482
The solenoid controller is in the HID ballast itself screwed to the bottom of the headlight.
The actual solenoid itself is in the headlight.
You could test it by removing the headlight and manually applying power to that solenoid.
It's switched on the +12v side so all you'd need to do is apply +12v to it. If you're not getting the light bulb out warning on your dashboard I think the solenoid itself went bad or the wire is broken.
Jas
Offline K9
  • VW LifeStyle
« Reply #8 on: December 27, 2014, 11:40:55 am »
Jas
how do i connect a 12v battery to the soleboid when the light is out? j screwed the whole light lens out and i manualy pushed the shutter close and open but still nothing happens when switching to highbeam etc. there are 3 wires going to the solenoid under the light lense inside the unit right? @jason_rmh  edit: tag me as i'm in the garage and i will get the email so i know when you answered thx  :happy2:
« Last Edit: December 27, 2014, 11:42:43 am by K9 »
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #9 on: December 27, 2014, 11:44:01 am »
I guess you need to figure out which is the power wire and which is earth.
Offline K9
  • VW LifeStyle
« Reply #10 on: December 28, 2014, 03:44:44 pm »
changed back to halogen units ( crap lightning  :sad1: ) do i need to screw the lens unit out from the housing?
