Author Topic: Snow foam  (Read 6310 times)
Offline Neil 54
Snow foam
« on: December 27, 2014, 11:47:49 am »
For those of you using snow foam do you use it every wash or only when really dirty
also just like to say how impressed i am with Gtechniq G6 perfect glass it is by far the best really easy to get great results
Offline Little_Dave
Re: Snow foam
« Reply #1 on: December 27, 2014, 10:02:42 pm »
I use it every wash but leave it to dwell longer if the car is dirtier than usual  :happy2:
Been using autobrite magifoam through the autobrite lance and am very happy with the results
Dave
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Snow foam
« Reply #2 on: December 28, 2014, 03:27:17 am »
X2 Once a week see's me okay :happy2:
Offline Biano44
  • The CC GT 200
Re: Snow foam
« Reply #3 on: December 28, 2014, 05:34:16 pm »
I only use it when the car is really dirty, which is nearly every time!
But I always use a PH neutral one.
Offline Chris92
  • -Given: 33
Re: Snow foam
« Reply #4 on: December 28, 2014, 07:01:23 pm »
Every time here too, even in the summer when it's just a little dust I still use it. It would just feel wrong not using it now before I wash it.
Offline xjay1337
  • -Receive: 377
Re: Snow foam
« Reply #5 on: December 28, 2014, 08:05:28 pm »
Its a pre wash aid.
so only should he really used when necessary.
If the car is just dusty then i wouldnt personally. But if its covered then it does help remove stubborn stuff prior to hand washing.
Offline Chris92
  • -Given: 33
Re: Snow foam
« Reply #6 on: December 28, 2014, 09:26:02 pm »
Its a pre wash aid.
Why? Apart from maybes wasted product but I'm guessing because it will affect the durable of the wax/sealant for the worst ?
Offline xjay1337
  • -Receive: 377
Re: Snow foam
« Reply #7 on: December 29, 2014, 09:10:55 am »
Its a pre wash aid.
Why take unnecessary steps??
Yes if you don't need it then why make the effort?
product cost
effect to lsp
extra time spent
dansmith180
Re: Snow foam
« Reply #8 on: December 29, 2014, 07:45:56 pm »
The idea of snow foam is to take dirt particles off the car so that you don't rub them into the paint with your mitt when washing. So if the cars just dusty then although there's not much point it does still help a bit, but its far more effective when the car is dirtier obviously.
When the car is only dusty some people just snow foam/ rinse and then dry the car so you don't have to touch the paint with a mitt but personally I never do this as its never properly clean.
Offline xjay1337
  • -Receive: 377
Re: Snow foam
« Reply #9 on: December 30, 2014, 01:19:42 am »
In the summer if it's not rained and you've only driven your car say around town for the shopping then there's absolutely no need to snow foam your car :) especially if it's well waxed and protected.
Unless of course you want to! because it is fun
but strictly speaking you're just using unecessary product and degrading your LSP a little bit quicker than necessary. rule #1 is always use the least aggressive method possible  :happy2:
dansmith180
Re: Snow foam
« Reply #10 on: December 30, 2014, 01:27:08 am »
Only problem with not snow foaming is then you can't take loads of pictures...  :rolleye:
Offline Hevoshullu
Re: Snow foam
« Reply #11 on: December 31, 2014, 08:31:15 am »
I would say that if the car is only slightly dusty/dirty AND well protected, you can wash it by only snow foaming and rinsing with a power washer. This in my opinion is the least aggressive method because there is no need for mechanical washing which will always cause more or less scratches/swirls even using the finest mitts made of lambs butt. Drying is done by gently placing and lifting large MF-towels on the paint and not dragging them towels on it. Also many snow foams are totally LSP-safe with correct dilutions.
Offline P3T3R
  • 05 GTI, R-Tech stage 1
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,82245.0.html
Re: Snow foam
« Reply #12 on: January 01, 2015, 07:35:55 pm »
I always use snow foam, but I only wash my car when it is visibly dirty  :evilgrin:
Offline xjay1337
  • -Receive: 377
Re: Snow foam
« Reply #13 on: January 03, 2015, 07:36:48 pm »
any shampoo is going to degrade LSP ever so slightly. saying it's LSP safe just means it's usually ph neutral(ish). you can be PH neutral and still an aggressive cleaner, carpro reset shampoo for example.
Offline Gripper1
Re: Snow foam
« Reply #14 on: January 24, 2015, 07:36:51 pm »
Where's the best place to buy snow foam .
Going to get a load of detailing essentials starting from scratch
