Author Topic: Plastidipped wheels care and cleaning  (Read 2896 times)
Offline omeydz
  • -Receive: 50
« on: December 27, 2014, 10:26:24 pm »
Hi all! Happy xmas and 2015!
Got merry with the plastidip and got a stealthy set of ed35 black alloys.
Look ace after 4 cans and some time n elbow grease. How best to make it keep its finish good for long as possible and how to wash it safely? No jet washing i presume?
Many thanks
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Plastidipped wheels care and cleaning
« Reply #1 on: December 28, 2014, 03:42:44 am »
Definitely do not use pressure....my front end bits always peeled. Got tired of redo-ing them. I just painted my wheels due to lack of confidence in plasti-dip. I would say use a diluted pressure washer cleaner in a spray bottle to pre-soak the wheels and gently rinse.
Offline howie1987
  • -Given: 92
  • -Receive: 21
« Reply #2 on: December 28, 2014, 03:44:31 am »
Hi m8. You can jet wash them. But just keep it back a bit. Use non acid shampoo and the autoglym rubber and vinyl care after that. Every 4 weeks or sooner. Thats what i do with my car that has been plastidipped.
Offline omeydz
  • -Receive: 50
« Reply #3 on: December 28, 2014, 01:04:58 pm »
Ah right. I think pressure wash is totally out the question.
Fitting them thismorning i had to redo 2 areas where it peeled of while handling the wheels. Gotta be so darn careful im thinking its going to be tough to keep them good. And at 10 plus a can its a bit of a false economy long term :P
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #4 on: December 28, 2014, 08:32:14 pm »
These 2 bits always peeled with 3 coats...
even with being careful of the nozzle distance of my washer. That being said, I believe with wheels one should cover both inside and out with plasti-dip to eliminate any ends or edges of the product other than at the outer rim. Also...it has been said to use 5 coats on wheels. You still need to be careful because if anything contacts or grabs onto the surface...it will peel.
My newly self-painted wheels however... :drinking:
I used flat blk. engine (high-temp and fluid resistant) paint that was 1/3 the cost of p-dip, but you cannot peel it off if one should change their mind.
I would just need to respray.  :happy2:
« Last Edit: December 28, 2014, 08:38:15 pm by ROH ECHT »
Offline omeydz
  • -Receive: 50
« Reply #5 on: December 29, 2014, 09:51:23 am »
Thanks a lot! Will tread/drive carefully and see how long it lasts.
Paint may be on the cards sooner or later. Definitely bored of bright silver coloured wheels.
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline alexharvey
« Reply #6 on: December 29, 2014, 10:36:22 pm »
you need loads coats with plasti dip mine lasted ages when i dipped them
i used normal alloy wheel cleaner and a brush always came up well and never messed them up
also depends on the dip u use if genuine or not
always jet washed mine no probs too
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #7 on: December 29, 2014, 11:45:31 pm »
↑ Right....heavy on the coats seems appropriate  :drinking:
Offline omeydz
  • -Receive: 50
« Reply #8 on: December 30, 2014, 10:24:32 am »
I did 1 can a wheel. Its Hyperlex German stuff 450ml cans.
Not worth shelling out another £50 for 4 cans imo. Rather paint them for that money!  :signLOL:
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9 on: December 30, 2014, 07:05:44 pm »
That was my thoughts, exactly, when I decided paint was the way to go. Luckily I had the experience of the peeling and wanted no part of it. Plus, it's not like I was ever going to change my mind on the color.  :drinking:
Offline omeydz
  • -Receive: 50
« Reply #10 on: December 30, 2014, 08:54:16 pm »
Well i guess plastidip is a good reversible way to test how a colour looks on your car before you get it permanently in paint.
On a lesser note I kerbed my wheel today and I wanted to cry! Plastidip lost vs the kerb. Came home and sprayed the areas over in plastidip n felt a bit better. pretty well hidden but you can see the corners of the peel area up close. I should use my self parking system more lol. In fairness wasnt used to how much the wheels stick out.
Current Rides
SOLD
2008 Audi A5 3.0TDI
