Author Topic: missfire  (Read 3013 times)
drewdrop
missfire
« on: December 28, 2014, 06:18:30 pm »
Hi people be easy first post, had my golf for 2 years now with Bluefin software happy with it until this morning runs normal round town and normal driving I hit a slip road and gave it some, what felt like a miss fire a sort of judder from the pedal happened and an engine management light flashed, I then eased off and the light stopped flashing and was ok to drive me home a further 10 mile. I tried on a straight close to home and the repeat  happened a misfire is this a common thing that goes wrong, I would like help so I can have knowledge before I see a garage tomorrow. ps always runs on Tesco momentum, and  serviced at main dealer 2 year ago when I got it, I only done 9000mile in 2 year is id due a dame good service ? please help its going in tomorrow for full going over thanks
Offline Leonpettit
  • 2008 Edition 30 DSG - No.1706
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89470.msg905534.html#msg905534
Re: missfire
« Reply #1 on: December 28, 2014, 06:52:11 pm »
Sounds like a coil pack. Had same symptoms a few weeks ago
Mods coming soon...
Offline Carl123
Re: missfire
« Reply #2 on: December 28, 2014, 07:28:06 pm »
Mine only misfires on idle had it plugged into vcds comes up cylinder 2 misfire gonna go with plugs first as still boosts very hard
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: missfire
« Reply #3 on: December 28, 2014, 09:49:24 pm »
Sounds like a coil pack. Replace them with the red ones in the link below. May as well do the spark plugs too - use Bosch plugs.
http://www.awesomegti.com/car/vw/golfmk5/red-ignition-coil-pack-set-2-0tfsi
Service your car every year as the oil degrades  :happy2:
drewdrop
Re: missfire
« Reply #4 on: December 29, 2014, 11:39:13 am »
Thanks been down today and the garage I use is closed, will be using wifes polo till the coil pack comes I will do it myself with plugs and oil cheers will let you know how I go
Offline Markyed30
Re: missfire
« Reply #5 on: December 29, 2014, 03:51:20 pm »
I had this only happend under load changed plugs and coils then realised I had a boost leak and it was an oring I needed
Offline Carl123
Re: missfire
« Reply #6 on: December 29, 2014, 07:56:43 pm »
Did you have yours plugged in on a vcds to see if any codes come up before you changed plugs and coils??
Offline Markyed30
Re: missfire
« Reply #7 on: January 01, 2015, 11:18:57 pm »
Yeh multiple misfires on cylinder 1,3 and 4 am sure it was and didn't happen on every pull and not long after I went from stage 1 to stage 1+
« Last Edit: January 01, 2015, 11:20:33 pm by Markyed30 »
