Author Topic: My Cupra K1 replacement-Golf R mk6  (Read 99640 times)
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
Re: My Cupra K1 replacement-Golf R mk6
« Reply #150 on: October 06, 2015, 04:51:27 pm »
bored over the weekend so wrapped the revo pipe in heat tape and exhaust wrap then cleaned and re-oiled the filter
bum dyno,the car felt a bit more responsive so worth the £20 outlay
fitting of the new hubs this week
Golf R mk6 R-tech tuned GTX3071r
Offline Gaz
« Reply #151 on: October 08, 2015, 01:53:02 pm »
Brakes look good and the heatwrap looks faster if nothing else!  :grin:
« Reply #152 on: October 08, 2015, 03:17:14 pm »
Was it already cam Coated Si?
Offline toosmiles
  • -Given: 22
« Reply #153 on: October 08, 2015, 11:07:21 pm »
yes mike  :happy2:
gonna wrap the dv pipe also,suprisingly warm after a bit of spirited driving :innocent:
Offline Gaz
« Reply #154 on: October 09, 2015, 08:06:53 am »
Thats probably because the air going through it is 40 degrees+ !
Offline toosmiles
  • -Given: 22
« Reply #155 on: October 09, 2015, 12:09:40 pm »
haha cant wait for some meth :party:
Offline toosmiles
  • -Given: 22
« Reply #156 on: October 14, 2015, 11:06:44 am »
Well ended up wrapping the dv pipe in the left over exhaust wrap as had no other use for it lol
Finally finished the hub swap.... a long story which i wont go into but its done,ill fit new track rod ends before wheel alignment then the whole lot has been new and will last for years to come:wink:
original steel hubs off and weighed are 8.8kg's so i saved 1.7kg's per side,nothing major but with the brake upgrade weight savings a total saving of 8.2 kgs per side on the front and savings on the walk kit and superpro arms it was well worth it
ill weigh the arms and walk for future reference later
cheers
Offline xjay1337
  • -Receive: 377
« Reply #157 on: October 14, 2015, 02:30:39 pm »
Those are the s3 hubs?
Offline toosmiles
  • -Given: 22
« Reply #158 on: October 14, 2015, 04:42:14 pm »
these are actually passat hubs jay,a third of the price of S3 ones :happy2:
Offline patpong_pete
« Reply #159 on: October 14, 2015, 05:26:36 pm »
Can also get the alloy passat wishbones
any one got a price say at TPS ?
thanks in advance
Offline toosmiles
  • -Given: 22
« Reply #160 on: October 14, 2015, 11:55:09 pm »
thanks in advance
i sourced my hubs off ebay and found a few passat wishbones going cheap pete :happy2:
also with help from a fellow member sourced an A3 rear crash bar to exchange mine,£30 posted was worth a try lol
all i had to do was drill this hole on the top right to fit the A3 one
1 M8 bolt and nut job done
total weight saving of 1.1kg's
Offline th3_f15t
  • -Receive: 183
« Reply #161 on: October 15, 2015, 12:48:06 pm »
Carbon fibre bonnet and wings next, loose another 15-20kg off the front end? :evilgrin:
Offline Gti_Mad
« Reply #162 on: October 15, 2015, 02:27:53 pm »
Have u got part numbers handy bud ??
Offline toosmiles
  • -Given: 22
« Reply #163 on: October 16, 2015, 12:19:36 pm »
bonnet deffo m8 :innocent:
what you needing m8?
« Reply #164 on: October 16, 2015, 12:46:28 pm »
alloy passat wishbones whats the part number or a link to ebay
i dont want to order the wrong part
thanks for help and reply
