Author Topic: Projector Headlights  (Read 22936 times)
Offline akbarirfan
  • -Given: 81
Re: Projector Headlights
« Reply #60 on: January 12, 2015, 02:15:02 pm »
Yeah to be fair I have never had such a close look before so not sure what it looked like before.
Coding is a must - without it the drivers side wouldn't say on. I am inclined to say that you don't need to spend the extra money on a Canbus compatible kit and can get away with a cheaper non-canbus kit and coding the car as a stated (a few on here have done just that for quite some time).
Offline ruhaleali
« Reply #61 on: January 12, 2015, 04:34:08 pm »
I went for the Canbus kit it was £40 with 2 yr warranty. I would not personally avoid £10 for stupid lights on the dash, and without the coding the system will work. On various models the lights tend to flicker, however, it isn't essential as my 2007 model doesn't suffer from any issues. And yeah I am going to look into this bumper alignment and see if I can adjust it more upload pictures of yours and i will too then we can compare!
Offline akbarirfan
  • -Given: 81
« Reply #62 on: January 12, 2015, 04:42:39 pm »
Oh right, mine did not work without the coding and are canbus compatible! Oh well.
Yeah will try and take some snaps tomorrow - but I fear there is nothing that can be done as there no play in the bumper at all.
The only thing I can think of is tightening the screws that meet with the wing, by the the wheels.
Offline ruhaleali
« Reply #63 on: January 12, 2015, 07:11:09 pm »
Thats true ! Im going to try that tommorow and see if it makes a difference and o! Probably depends on the type of HID.
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #64 on: January 13, 2015, 07:54:09 pm »
Can I buy Depos and fit genuine ballast, igniter and xenon bulb to it?
Like, does it have the structure to hold the bulb/igniter and have cables/connectors for the igniter/ballast?
Offline akbarirfan
  • -Given: 81
« Reply #65 on: January 13, 2015, 07:55:15 pm »
Genuine bulbs are D2S, not sure they will fit into the H7 socket.
« Last Edit: January 14, 2015, 03:31:33 am by akbarirfan »
Offline Rossimac
  • -Given: 78
« Reply #66 on: January 14, 2015, 12:03:23 am »
http://www.ebay.co.uk/itm/121237144928?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
That one takes D2S and H7 and is for RHD.
Would this work with standard xenon D2S/Igniter/Ballast? I've tried asking the seller, but no response yet.
Offline ruhaleali
« Reply #67 on: January 14, 2015, 12:45:56 am »
Depends on the type of Depo pal! The supplier will tell you as some take D2S and need VAGCOM coding. The pair on ebay going for £230 are d2s but apparently the sidelight positioning is not the same its the same as the halogen projector.
Offline akbarirfan
  • -Given: 81
Offline ruhaleali
« Reply #69 on: January 14, 2015, 08:15:35 pm »
Here are mine:
https://drive.google.com/file/d/0By82c7wS-lNXYnVYclBXeUpHRDQ/view?usp=sharing
I have a serious problem, my sidelight fell into the sidelight section. How can I get this out ?
Offline samiul11
« Reply #70 on: January 15, 2015, 10:41:56 am »
I've just installed a hid kit, do i need to code it with vagcom? What will happen if i dont?
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #71 on: January 15, 2015, 10:48:01 am »
I haven't but I have a canbus kit and all fine d
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline akbarirfan
  • -Given: 81
« Reply #72 on: January 15, 2015, 10:51:50 am »
Turn on the lights and see what happens mate - in my case, the passenger light worked but the drivers side went out after a couple of seconds.
Coding cured it, now it always perfectly.
Offline chrisr763
  • -Receive: 62
« Reply #73 on: January 20, 2015, 12:28:06 am »
Anyone found a set that as the sidelights where the indicators are? Could you possibly post up a link?  :P
Offline chrisr763
  • -Receive: 62
« Reply #74 on: January 20, 2015, 12:48:36 am »
