Author Topic: a bit of a problem vcds codes and i dont no where to start  (Read 2901 times)
Offline Jai86
  • hiiiiii :-D
« on: December 30, 2014, 10:10:48 am »
hey had a few lil problems like my car being down on power limp mode and so on just wandered if any one could shed some light on the situation
its a 58 plate golf gt tdi sport L
2.0 bkd engine
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  4661
   Revision: --H09---    Serial number: VWX7Z0H93NA025
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 7CF184B23F9C0DFEC75-8029
3 Faults Found:
001025 - EGR System
               P0401 - 000 - Insufficient Flow
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 255
                    Mileage: 169359 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:58:39
             Freeze Frame:
                    RPM: 1470 /min
                    Speed: 52.0 km/h
                    Load: 7.5 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 58.0 %
                    Mass Air / Rev.: 265.0 mg/str
                    Mass Air / Rev.: 525.0 mg/str
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 3
                    Fault Frequency: 53
                    Reset counter: 255
                    Mileage: 169361 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:02:15
             Freeze Frame:
                    RPM: 1029 /min
                    Speed: 26.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 169563 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:31:59
             Freeze Frame:
                    RPM: 1932 /min
                    Speed: 50.0 km/h
                    Load: 16.9 %
                    Voltage: 13.83 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 1 1 0 0 0
the central electronics are just bulbs but the engine part thats a lil diff ha
just need a little bit of help from what i think is the best forum
Offline Matto
  • -Receive: 116
Re: a bit of a problem vcds codes and i dont no where to start
« Reply #1 on: December 30, 2014, 10:34:22 am »
My first port of call with any faults is the Ross-Tech Wiki site.
First one could be that the EGR is blocking up and needs a clean. They are prone for getting sh*t up.
http://wiki.ross-tech.com/wiki/index.php/16785/P0401/001025
http://wiki.ross-tech.com/wiki/index.php/16725/P0341/000833
http://wiki.ross-tech.com/wiki/index.php/18106/P1698/005784
Offline Jai86
  • hiiiiii :-D
« Reply #2 on: December 30, 2014, 10:46:10 am »
Oh sweet iv just had a look there's a bit oil coming from the asv I guess there's a problem there
Offline Matto
  • -Receive: 116
« Reply #3 on: December 30, 2014, 11:53:37 am »
The ASV's are prone to failing also but you aren't getting the fault code for that. I took one apart a while a ago to see why it failed.
http://www.mk5golfgti.co.uk/forum/index.php/topic,75990.msg798935.html#msg798935
Offline Jai86
  • hiiiiii :-D
« Reply #4 on: December 30, 2014, 09:17:46 pm »
mate you are a legend i just had a look at the asv and theres oil coming out of it and that code did come up before on a different machine though that could be a cause i will price that up :-D
Offline Matto
  • -Receive: 116
« Reply #5 on: December 30, 2014, 10:33:02 pm »
No worries mate. Try Euro Car parts and search the internet for a discount code. Will normally have them in stock  :happy2:
