Author Topic: Das-6 pro polisher setup?  (Read 2395 times)
Offline jimmy-s3
« on: January 02, 2015, 04:46:57 pm »
I've just bought a das-6 pro polisher for my black Mk5..
As a beginner, I'm struggling to decide which pads and compounds to buy to get me going?
Any advice is welcome!
dansmith180
Re: Das-6 pro polisher setup?
« Reply #1 on: January 02, 2015, 05:25:59 pm »
The paint on these is quite hard so you need a fairly aggressive setup.
Personally I like the microfibre pads with Megs 105/205 or Menzerna FG400. I also find the chemical guys Hex-Logic pads very good also used with the above polishes.
Orange Hex-Logic with FG400
Or
Microfibre cutting disc FG400
Or
Microfibre cutting disc Megs 105
Microfibre finishing disc Megs 205
Any of these combos would do do well, I find the Megs 105 does need refining afterwards with the Megs 205 whereas the Menzerna FG400 doesn't but it does give a slightly better finish after because of the refining.
Offline andy7ven
  • -Receive: 30
« Reply #2 on: January 02, 2015, 05:35:38 pm »
I'd also recommend the Chemical Guys Hex-Logic pads heres a guide to them  :happy2:
http://www.detailingworld.co.uk/forum/showthread.php?t=284956
Also the Chemical Guys V Line polishes are excellent (and smell nice) too...
« Last Edit: January 02, 2015, 05:37:51 pm by andy7ven »
Offline jimmy-s3
« Reply #3 on: January 02, 2015, 05:53:18 pm »
So should I go for the hex pads in the hard paint range?
Am I best of using a microfibre pad as a finishing pad rather then a hex pad for finishing?
Also, would I need a 4" or 6" pad?
dansmith180
« Reply #4 on: January 02, 2015, 06:00:35 pm »
For your polishing pad you'll want a hard one
You can use either microfibre or hex
And assuming you've got the standard backing plate you'll want 5" pads
Shedboyzz
« Reply #5 on: February 16, 2015, 12:30:58 am »
Remember to polish inside. Do not machine polish in the open air, if you can help it
