Author Topic: Upgrade to r32/s3 brakes worth it?  (Read 6665 times)
  • -Receive: 427
Re: Upgrade to r32/s3 brakes worth it?
« Reply #15 on: January 04, 2015, 09:08:12 pm »
Hay Dom  :drinking:
If you consider the Porka anchors have a look in my build thread for part numbers and links to DaveB's NQSBBK thread etc etc, page 1 in my thread IIRC. Great set up and more than capable of looking afte my Stage2+ Mistress. My set up was under £1k once and that's once id had the calipers refurb'd, bought the fitting kit, added new discs and new pads and shims, fresh fluid and fitting so not too bad.
And yes you'll need spacers for the NQSBBK if you have 7.5" ET51 whereas you won't need them with the R32 calipers with those wheels. No need for spacers with most set ups if you have 8" ET44 (ish).
Offline th3_f15t
  • -Receive: 183
« Reply #16 on: January 04, 2015, 09:10:06 pm »
Knew you'd be along soon enough to save the day! :P
  • -Receive: 427
« Reply #17 on: January 04, 2015, 09:14:10 pm »
^^^^ Yeap!  :wink:
Offline DomBacon
« Reply #18 on: January 04, 2015, 09:14:45 pm »
Hay Dom  :drinking:
Ok mate cheers I'll have a little look through! What size spacers would I need with this kit? 7.5" et51
« Reply #19 on: January 04, 2015, 09:17:33 pm »
If your not racing it around the track then the r32 set up is the way forward especially when you do the rears as well
  • -Receive: 427
« Reply #20 on: January 04, 2015, 09:26:12 pm »
H&R 8mm Hubcentric spacers will be the puppies your after. Contact Alex at AKS for them if you go that route.
My 8" ET44 wheels allow 13mm more clearance for the NQSBBK over standard wheels......
dansmith180
« Reply #21 on: January 04, 2015, 09:29:16 pm »
We didn't need a picture you big show off  :booty:
« Reply #22 on: January 04, 2015, 09:38:01 pm »
have you got a picture to see how far your car is lowered Martin..My wheels are the same of set as your car and keep thinking of going bigger brakes but not sure if I will start catching the arches with spaces on
  • -Receive: 427
« Reply #23 on: January 04, 2015, 11:13:51 pm »
@dansmith180     :P
@maxitrol  those are my 18" VZ's fella, your being 19" CK's?. Carlo's is lowered now on Coils IIRC and still rolling on 19"s. Don't think he had any problems with just the H&R either.
« Reply #24 on: January 04, 2015, 11:28:22 pm »
Cheers Martin for the info some thing about now as would like bigger brakes on the front to fill  my wheels up  :signLOL:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=irj4dv3shoalccv016cmrvrpom&/topic,19740.0.html
« Reply #25 on: January 04, 2015, 11:30:18 pm »
What about the twin pots with 360mm disc?
« Reply #26 on: January 05, 2015, 12:23:19 am »
Oh tell me more Rich
« Reply #27 on: January 05, 2015, 12:26:15 am »
Do a search on here and Google. Top cat had them I believe.
Offline DomBacon
« Reply #28 on: January 10, 2015, 01:15:16 am »
I'm thinking r32 brakes so I don't have to get spacers but then I guess the NQSBBK kit is lighter and obviously 4 pot and the wheels I want are et45 8.5j
Offline DomBacon
« Reply #29 on: January 30, 2015, 05:31:31 pm »
Looking at r32 fronts and rears, I don't take it on track but I do love a country road drive  :driver: will I see a decent improvent to benefit spending the money on them? Cars running about 320bhp at the moment
