Author Topic: UK 2.0 TFSI/TSI Top 20 Leader Board Discussion Thread  (Read 109835 times)
Offline Janner_Sy
  • -Receive: 113
Re: UK 2.0 TFSI/TSI Top 20 Leader Board Discussion Thread
« Reply #240 on: May 26, 2010, 07:05:48 pm »
im all out of ideas then
maybe try a vRS instead :P :grin:
Offline djhorace
« Reply #241 on: May 26, 2010, 07:08:19 pm »
I am wondering what difference slicks would make to the 60 foot time over say 888's?
Offline Blade
  • Taking a sabatical from cars
« Reply #242 on: May 26, 2010, 07:27:01 pm »
At what point do you change gear Al - rev limiter or a certain point on the tacho?
Offline Janner_Sy
  • -Receive: 113
« Reply #243 on: May 26, 2010, 07:28:54 pm »
thats a fair point.  on your dyno graphs, where abouts does the power/torque/boost start to tail off.  iknow on the k03 changing gear at about 5250rpm makes more progress
Offline djhorace
« Reply #244 on: May 26, 2010, 07:32:20 pm »
Not sure really. I dont look at the rev counter - I do it by ear. Maybe I should try changing sooner. Have a listen here. Must be about 6500-6750rpm
Offline Janner_Sy
  • -Receive: 113
« Reply #245 on: May 26, 2010, 07:37:05 pm »
you got any dyno graphs or boost logs to see how the car is performing.
Offline djhorace
« Reply #246 on: May 26, 2010, 07:38:44 pm »
Not since the new intake, a/c off and RS4 valve in with new settings on Revo, no :(
Offline Janner_Sy
  • -Receive: 113
« Reply #247 on: May 26, 2010, 07:39:36 pm »
get it done :grin: :jumpmove: :jumpmove:
Offline djhorace
« Reply #248 on: May 26, 2010, 07:42:13 pm »
Yes boss  :laugh: - or should I wait until WMI is onboard  :pomppomp:
Owen and I were also speaking about ditching the S3 cooler for a THS one. Not convinced the Forge would work any better than a single thick core given we have no a/c to worry about but WMI should do a good job too.
« Last Edit: May 26, 2010, 07:45:17 pm by djhorace »
Offline Blade
« Reply #249 on: May 26, 2010, 07:45:49 pm »
I was going to say you could hold onto a gear longer - mine will rev to just under 8k
Offline djhorace
« Reply #250 on: May 26, 2010, 07:48:20 pm »
Yeah, it would be doable, but there is a point in the revs where it makes things quicker to change to the next gear. You will hear on the clip above that the car is absoluely balls out in 4th. With no passenger and no passenger seat, it gets there sooner.
Offline Janner_Sy
  • -Receive: 113
« Reply #251 on: May 26, 2010, 07:51:21 pm »
thing is though the best thing about the forge is the increase in surface area for cooling
Offline djhorace
« Reply #252 on: May 26, 2010, 07:58:20 pm »
Yeah, I have thought about that, but realistically, the S3 core blocks part of the OEM core anyway. That plus the fact I would need to get a mix match kit - Leon core and S3 pipes which will be a pain when I come to sell them.
Then there is the extra weight of another core ha ha ha!
« Last Edit: May 26, 2010, 08:00:33 pm by djhorace »
Offline GTIjames
« Reply #253 on: May 27, 2010, 09:22:33 am »
lightweight battery helps, but you will notice you need to adjust your ride height afterwards from taking 15kg off from one side of the engine  :happy2:
do you guys get BP102ron up in scotland? as thats worth a punt, i certainly noticed the difference from vpower the times i have tried it but not cheap at over £2 a ltr
tyres i would go r888 as its what all the people running the best times are using, no point trying something else when these are proven, and then try out different tyre pressures to see what you launch best with
these guys are selling off there toyos, at £165 per corner compared to £199 from camskill  :happy2:
http://www.tyretraders.com/tyresearchresults.aspx?width=225&ratio=40&rim=18&man=Toyo&flat=False&filter=Price&ftype=Ascending&pricing=1&cat=All&speed=All&Loading=All
im missing the pod its been over 2 months since my last outing, will be the first thing i do when i get the car back   :party:
« Last Edit: May 27, 2010, 09:32:17 am by GTIjames »
« Reply #254 on: May 27, 2010, 09:48:10 am »
....Glad to see you staying positive, buddy  :happy2: - As one door closes, another one opens  :pomppomp:
