Author Topic: Coolant temperature gauge fluctuations  (Read 3896 times)
Offline jakex181
« on: January 07, 2015, 11:51:24 am »
My temperature gauge seems to be fluctuating while im driving, it is slow to get up to 90 and seems to move from 90 back down 1 or 2 divisions and back up continuously. I have read many forums and believe it is an issue with the temperature sensor/main thermostat/inline thermostat.
I am just wondering if there is an order i should start replacing parts in or if i can narrow it down to one of these 3 possibilities.
I used to have VCDS but it no longer works so is there any ways i can tell physically rather than reading fault codes?
Also what are the part numbers for these components? I have a 56 plate golf GTi, im not sure if the BWA and AXX engines are different.
Jake
Offline DomBacon
Re: Coolant temperature gauge fluctuations
« Reply #1 on: January 07, 2015, 11:58:58 am »
I'm having the same problem at the moment as well
Offline GTi-Andy
« Reply #2 on: January 07, 2015, 12:19:58 pm »
there seems to be a common theme running at the moment regarding these kind of problems
A lot of members seem to be having thermostat problems.
So much for keeping it standard!
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: January 07, 2015, 12:35:59 pm »
Jake
Very common problem, do you have manual or dsg?
Manual has two, dsg has 3
Manual has main thermostat and inline thermostat
Main thermostat from VW is about £300, not sure about inline thermostat but it is cheaper.
Chances are both have gone or will go soon!
If you're a very capable mechanic, it can be done but it's a big task!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: January 07, 2015, 01:01:07 pm »
I had that exact problem: http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.0.html
Fixed with a new thermostat
Offline jakex181
« Reply #5 on: January 07, 2015, 01:18:55 pm »
i have a manual,
so am i right in saying it is not the temperature sensor and that i am best to change the main thermostat first?
Id do the job myself so as to reduce costs, does anyone know the part number required?
Jake
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: January 07, 2015, 02:29:32 pm »
i have a manual,
Jake
I started with the main thermostat and although my gauge now reaches 90 it takes 30mins to get there which leads me to believe my inline is gone.
VW garage as I said is expensive but and independent then did it for €225.
I'm sure someone else can shed light on the part number but from what I hear, it's challenging enough!
Offline jakex181
« Reply #7 on: January 14, 2015, 08:20:54 am »
I have done some logging using Torque App on my phone, this is my first time using the app
Does this graph confirm that it is definitely the thermostat?
http://s18.postimg.org/on9dzg221/Screenshot_2015_01_14_08_02_38.png
Offline JMP
« Reply #8 on: January 14, 2015, 10:36:26 am »
It does look like your thermostat starts to pass coolant already at about 65 degrees. It should go to about 87, I think the main thermostat temp rating is that. I have same problem, mine seems to settle around 75 degrees when outside temp is about -15 degrees celcius. The analog needle shows 90 but the real temp is lower. When there was -23 degrees the analog meter didnt want to show 90 anymore.
I changed my inline thermostat on top of dsg box, but I still need to change the main thermostat also which requires more work.
