Author Topic: Air con leak, or not?  (Read 1061 times)
Offline screech
« on: January 08, 2015, 05:20:40 pm »
Hey guys,
Just looking for some opinions.
Had my car 3 months and was advised my aircon was leaking, so had dye put in it.
Took it back to where I got it today for it to be looked at/repaired under warrantee.
They've said they can't find a fault, and that all they can see is some dye around the seals, but that's normal.
Are they just fobbing me off..??
Offline doylebros
Re: Air con leak, or not?
« Reply #1 on: January 08, 2015, 07:06:10 pm »
How did the person who noticed it leaking originally see the problem thus requesting dye to be added to aid finding a leak in the future?
However,If it was a case of recharge with dye sorted the original problem and now the gas has gone I suggest you use an independent party to look in the common areas like - condenser and pressure switch (electrics connection point).
Offline W6llace
« Reply #2 on: January 08, 2015, 09:59:35 pm »
Check the heater vents for dye as not everyone looks if the evaporator is leaking
