Author Topic: Etka request for MK6 MF steering wheel parts  (Read 3764 times)
Offline jedi-knight83
  • -Receive: 41
« on: January 08, 2015, 08:47:36 pm »
Can someone help me with a part.
Bought a mk6 gti steering wheel for my van and the buttons on the left don't work or light up. Its been coded properly and the deg paddle on that side works just fine.
The seller has agreed to part refund the cost for any parts to repair it.
I gather the grey ribbon cable can be disconnected from the back of the buttons so is this a separate part that can be bought. Also is the button module separate or do you need to buy the whole chrome effect bit with both left and right buttons?
Thanks in advance.
Offline doylebros
  • -Receive: 310
Re: Etka request for MK6 MF steering wheel parts
« Reply #1 on: January 08, 2015, 09:05:59 pm »
This part is year dependant so keep this in mind!
Item 17 is the part you need for the switch cluster only sold as both side £149.24 full retail inc vat.
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1737&ein=2011&f=649&hauptgr=1234567890&hg=9&grf=095355649&bf=95355&hgug=953&ug=53&parent_id=3067254&detail_id=3067303
  • -Receive: 41
« Reply #2 on: January 08, 2015, 09:16:26 pm »
thank you.
this image shows the ribbon cable disconnected from the back of the switch
so surely the grey ribbon cable is available somewhere?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #3 on: January 08, 2015, 09:16:50 pm »
The part I believe you need is 25A. You might want to double check the part number first and like said sold as both sides
Offline doylebros
  • -Receive: 310
Offline doylebros
  • -Receive: 310
« Reply #5 on: January 08, 2015, 09:24:04 pm »
That is correct but you need to know the year of your set -  those above are for before May 2010
The I posted is more common and for item after May 2010
« Last Edit: January 08, 2015, 09:25:46 pm by doylebros »
  • -Receive: 41
« Reply #6 on: January 08, 2015, 09:25:26 pm »
You may be able to use these bits to sort your problem
http://www.ebay.co.uk/itm/111567312015?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Or look at the Chinese one offered on EBay and just use the cable
http://www.ebay.co.uk/itm/MF-Steering-Wheel-Control-Button-Left-For-VW-Eos-Jetta-Golf-MK6-MKVI-Passat-CC-/161505613983?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item259a7c189f
Like I said its year dependant!
annoyingly both the wrong buttons. they are the volume buttons. The fault is with the other side and the ribbon is different. thank you though. I did see that £5 one :)
Offline doylebros
  • -Receive: 310
« Reply #7 on: January 08, 2015, 09:31:46 pm »
  • -Receive: 41
« Reply #8 on: January 10, 2015, 02:37:05 pm »
Took the new wheel apart more today and took the buttons off.. the red plug on the ribbon cable was only half pushed in on that side. Popped it back in and hey presto the buttons work.
Thanks for everyones help though.
Case closed.
