Author Topic: DV valve  (Read 810 times)
Offline poweller
DV valve
« on: January 09, 2015, 10:54:48 am »
Hi all,
Could anyone advise me on which DV to purchase and where is the best placw to get it?
Thanks Sean
Offline th3_f15t
  • -Receive: 183
Re: DV valve
« Reply #1 on: January 09, 2015, 11:04:12 am »
Use the search features mate, there's tons out there already just a few key presses and clicks away. :fighting2:
Offline allymac
Re: DV valve
« Reply #2 on: January 09, 2015, 11:08:53 am »
As above everything is only a click away and a search, just to give you a helping hand rev G and probably a site sponsor or VW parts themselves should be sub £40.00 HTH
Offline poweller
Re: DV valve
« Reply #3 on: January 09, 2015, 12:06:57 pm »
Thanks all, i use the tapatalk forum apps and on my version the search button brings up non related posts!
Offline john87
  • -Receive: 53
Re: DV valve
« Reply #4 on: January 09, 2015, 12:26:38 pm »
I have a Revision G (Less prone to leak than the newer revision D) valve that's brand new if you want it?
I ended up with two after an ebay mix-up, £20 delivered?
Same as the one on the left (right hand side is revision D):
