Author Topic: Xenon headlight lug repair kit - info needed  (Read 5890 times)
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« on: January 09, 2015, 03:21:59 pm »
Picked up a set of Xenon headlights from a breakers earlier - the clips have broken on both headlights.
I've read about a kit that can be bought from Volkswagen to repair the clips - phoned my local parts department but they had no knowledge of it.
Searching under my chassis number was useless as I don't have factory-fitted xenon headlights.
Does anyone have any information on this kit? Or if anyone with xenons would be so kind as to ring up VW with their chassis number and enquire about it (or PM me their chassis number so I can do it), that would be awesome!
 :drinking:
Offline Rossimac
  • -Given: 78
Re: Xenon headlight lug repair kit - info needed
« Reply #1 on: January 09, 2015, 03:25:02 pm »
Offline Rossimac
  • -Given: 78
« Reply #2 on: January 09, 2015, 03:39:01 pm »
£24.80 for each side.
« Last Edit: January 09, 2015, 04:50:08 pm by Rossimac »
Offline SI-R32
  • -Receive: 126
« Reply #3 on: January 09, 2015, 03:45:42 pm »
Hi 1J0 even though one of his packets show this is for the mk4
you need to start both numbers with 1K0 for the mk5
Offline Rossimac
  • -Given: 78
« Reply #4 on: January 09, 2015, 03:48:03 pm »
I've just had a thought.
To avoid the need to buy a Kufatec adapter - can I not just lift out the wiring from this car instead? The breakers has all of that stuff remaining. What should I lift out of the car to fit to mine?
Offline Rossimac
  • -Given: 78
« Reply #5 on: January 09, 2015, 04:49:51 pm »
Excellent work! I saw the top part number from the linked thread and phoned VW and they said that was the one.
I'll phone VW again. Cheers for the heads up.
Offline Rossimac
  • -Given: 78
« Reply #6 on: January 09, 2015, 05:52:36 pm »
Also, what do people think of this?
As you can see the lens has had impact damage and the housing around the projector seems to be damaged.
Can I use the lens from my halogen headlight to fix this? VW quoted me £175 for the lens.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: January 09, 2015, 06:05:30 pm »
Yeah, that looks fooked, I wouldn't touch that if I was you. Have you actually inspected the lights? The internals ok?
Offline Rossimac
  • -Given: 78
« Reply #8 on: January 09, 2015, 06:17:21 pm »
Well, I agreed a price and collecting them tomorrow so will get a good look at the them before actually buying them! If it's beyond repair, I'll pass. But what are the odds of repairing it with my halogen lens?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #9 on: January 09, 2015, 06:29:26 pm »
I wouldn't touch that either. I reckon the insides will be buggered. That's more than just the broken lugs. I fitted a lug repair kit today ( I work in a bodyshop ) and you have to make sure that where the kit screws to are in tact and if they are you might need to shave some of the plastic off to fit the kit but not a bad job really. If I'd known I would have taken pics when I did it
Offline Rossimac
  • -Given: 78
« Reply #10 on: January 09, 2015, 06:38:41 pm »
Well, the left light is good, just broken lugs on it. So just going to get it and wait it out until I can get the right one elsewhere. Only £70 for the pair including auto leveller system.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #11 on: January 09, 2015, 07:48:01 pm »
Looks to be alot more damage than just the lens though. I'd say the internals are shagged by the looks of it. At £70 quid for the lot with levellers thats not bad if you could salvage the igniter & ballast from the right light, then just look for a bare light.
Is it from an R32? Just be careful if your fitting the levellers to a GTI, as the R32 sensors have different brackets for the rear
EDIT: Can see the red stripe on the grill of a gti, you should be good on the sensor front  :happy2:
« Last Edit: January 09, 2015, 07:49:43 pm by fab5freddy »
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #12 on: January 09, 2015, 07:56:36 pm »
have you got the retro fit loom?
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Rossimac
  • -Given: 78
« Reply #13 on: January 09, 2015, 08:14:32 pm »
Yeah it's a GTI. Breaker says both lights are working, just the lens is cracked, but I can clearly see the projector housing is broken, so it'll be as you say - pull the internals and wait for a faulty or empty shell.
Hoping to pull the headlight washers as well, but not hopeful they're still on the vehicle.
Offline Rossimac
  • -Given: 78
« Reply #14 on: January 09, 2015, 08:21:29 pm »
No. Is this the kuftatec adaptors or the loom to the rear level motor? I was hopeful to pull the wiring for both units and perhaps skip on the kuftatec adaptors.
I haven't seen any info on whether this is possible and will need the kuftatec adaptors if so!
