Author Topic: Amps, Subs and Shizz  (Read 1307 times)
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
« on: January 10, 2015, 10:40:15 am »
Guys, after some info, done some searching but just wanted a few views/answers to the following...
I fancy a sub in the boot to improve the overall sound, I currently run a RCD510 DAB and wanted to ask if I am better off buying an AMP with high level imputs rather than use LOC to convert to RCA's?
I was looking at a JL Audio JX250 with a JL SUB?
Also best location for install? would you tee off the rear left speaker and install amp in boot? or under front passenger seat?
And best place to pick up a remote switch on for the amp? Stereo of other AUX device inside the car?
Any views would be great.
Pirelli GTI
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=hk6t1cr7ji2m9aggbtc6odci67&/topic,90967.msg917089.html#msg917089
Re: Amps, Subs and Shizz
« Reply #1 on: January 10, 2015, 11:45:03 am »
I have a JX amp under the drivers seat. Tapped into the front speakers behind the head unit.
As you can see it does get kicked a bit.
I connected remote to the power wire for my Parrot Blue Tooth as the front 12v socket was always on.
05 | Tornado Red | DSG
« Reply #2 on: January 10, 2015, 12:40:34 pm »
i put my amps in the boot under a false floor--have a look in my build thread
Offline jedi-knight83
  • -Receive: 41
« Reply #3 on: January 10, 2015, 01:24:40 pm »
check my build thread
I've got audition bit ten under drivers seat and a jl xd400/4 under the passenger seat. all hidden away and very oem+
Offline gixerben
« Reply #4 on: January 10, 2015, 03:39:13 pm »
cheers guys, some great builds.Does the sub addition make a massive improvement?
Pirelli GTI
« Reply #5 on: January 10, 2015, 07:13:34 pm »
for me it does as i listen to hard house music most times
