Author Topic: Rear wiper problem  (Read 798 times)
Offline Carla77
Rear wiper problem
« on: January 10, 2015, 11:45:04 am »
Hi,
My rear wiper has developed an annoying fault where it is continuously wiping (no matter which position the steering column stalk is in). I've tried switching the engine off and restarting but it's happening all the time. I've taken the fuse out to stop it working but obviously need to sort it out.
Any advice or recommendations would be really welcome
Offline th3_f15t
  • -Receive: 183
Re: Rear wiper problem
« Reply #1 on: January 10, 2015, 12:06:11 pm »
As with any electrical fault, get a VCDS scan to identify any problems. At a guess it could be a broken relay if its continually opperating.
Offline Stevepd
  • -Given: 49
« Reply #2 on: January 10, 2015, 03:33:33 pm »
I've got the same thing, I also had to remove the fuse. Last weekend I did some investigation and took the rear panel off to have a look at the wiper motor and the connector, checked the operation of the relays which were good, so my next port of call is the stalk?. Either way I lived with it......
Let me know how you get on.
Steve.
Standard 5 Door Shadow blue.
Offline doylebros
« Reply #3 on: January 10, 2015, 05:34:13 pm »
Check the tailgate wiring within the rubber banjo before buying any parts  - wiring failure in this area cause all sorts of interesting problem :happy2:
Offline Carla77
« Reply #4 on: January 10, 2015, 07:47:57 pm »
Thanks for the responses...will keep you updated once we've sorted it.
