Author Topic: Rear boot badge  (Read 1407 times)
Offline Cossie Killer
Rear boot badge
« on: January 10, 2015, 10:06:14 pm »
Evening all,
Can anyone advise firstly what badge this is (3D?), secondly, is there anyway of removing and replacing without removing the whole handle?!
Have been searching but still none the wiser...
Cheers.
Re: Rear boot badge
« Reply #1 on: January 11, 2015, 03:55:37 pm »
Can anyone help?
Offline AndyBrown
Re: Rear boot badge
« Reply #2 on: January 11, 2015, 04:05:53 pm »
You can pry it off, gently!
Re: Rear boot badge
« Reply #3 on: January 11, 2015, 04:25:18 pm »
Thanks Andy!
Offline missymckay
Re: Rear boot badge
« Reply #4 on: January 11, 2015, 08:32:22 pm »
I managed to get the vw bit off mine but snapped it. Had to get a new one from an American website as couldn't find a replacement on ebay. I now have one in gloss black  :laugh:
AmD stage 1
Offline JC88
Re: Rear boot badge
« Reply #5 on: January 12, 2015, 09:45:46 pm »
If you use a thin small screwdriver to initially pry away the bottom of the badge at the 6 o clock point, then you can use a credit card or trim removal tool to gradually shimmy round and prise the badge off the back. The mk6 bevelled badges fit onto the mk5 rear mechanisms too but i think there were two clip patterns so some mk6 badges need some tabs to be broken off etc.
bit of patience and sometimes a soak in hot water helps get the badge off easier! Hope it helps!
Re: Rear boot badge
« Reply #6 on: January 12, 2015, 10:45:13 pm »
Will give it a go when it stops raining!
