Author Topic: aluminium / alloy s3 wishbones fitted  (Read 17482 times)
Offline BMX
« on: November 21, 2009, 01:29:11 pm »
fitted my s3 alloy wishbones and s3 bushes today, couldnt beleve how heavy the standard gti wishbones were
gti = 4100 grams each
s3 = 2290 grams each
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Offline Janner_Sy
  • -Receive: 113
Re: aluminium / alloy s3 wishbones fitted today
« Reply #1 on: November 21, 2009, 01:33:40 pm »
I think they have them fitted to counteract the extra weight of the S3 brakes, the cupra has the same iirc. how much did they cost you.
i think id splash out for the TT lower control arms, aluminium but with additional camber adjustment
Offline BMX
« Reply #2 on: November 21, 2009, 01:50:11 pm »
yeh thats what i thought they might be for, goood job i had the brakes already  :happy2:
they were £90 with the bushes all in mint condition, well happy
does the r32 have them too seen as that has the bigger brakes??
Offline jonnyc
  • Herrooooo!
« Reply #3 on: November 21, 2009, 01:52:07 pm »
S3 hubs are alloy too.. Im planning on doing both for mine now.. Plus Scirocco rear hubs and bottom arms, all alloy.. All helps for sure!
I think there is a good 20kg in replacing all the suspension components to the alloy items! Plus its all unsprung mass, so its extra important!  :smiley:
Offline keith
« Reply #4 on: November 22, 2009, 09:49:12 am »
Whats the part no's for the S3 bits BMX?
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #5 on: November 22, 2009, 10:08:19 am »
keith, I've been looking at these
Part Nos:
1K0 407 151 AK
1K0 407 152 AK
Think they're 80 quid a piece
Offline keith
« Reply #6 on: November 22, 2009, 10:22:51 am »
Thanks Dave
I am going to Trade parts place this week who spec in Vag parts so going to see what they quote me.
Offline tony_danza
  • -Receive: 112
« Reply #7 on: November 22, 2009, 10:33:01 am »
Tell me more....
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: November 22, 2009, 11:07:31 am »
when briskoda comes back online, ill post up all the part numbers and bits required to do the job
essentially the TT has an additional 0.5degree adjustable camber, std i believe you rare loking at 1 degree negative, so with the TT lower arms(FWD) you can have 1.5 degrees negative. Not a huge increase but i bet more than enough to make it go through corners alot better.
I actually purchased a set back along, then sold swapped them with a friend for his H2sport top mounts which i decided to sell on.
heres a review of them inaction http://www.audi-sport.net/vb/showthread.php?t=71940&highlight=lower+arms
Offline BMX
« Reply #9 on: November 22, 2009, 11:49:41 am »
had a good drive this morning and can defo notice the difference, feels really smooth over bumpy surfaces alot less crashy over potholes etc, cant really say i noticed much cornering wise, glad i did it though. not really bothered about the extra camber to be honest
Offline tony_danza
  • -Receive: 112
« Reply #10 on: November 22, 2009, 11:55:32 am »
Cheers Simon/BMX.
I've been loking for a second hand set for a while, due to the weight - I didn't know they had a tweak more camber too. I'll start looking harder.
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: November 22, 2009, 12:15:22 pm »
the S3 lower arms dont have the additional camber though according to vRStu, when he had a look at his.
Offline tony_danza
  • -Receive: 112
« Reply #12 on: November 22, 2009, 01:55:31 pm »
Ahh - well I'll see what the TT ones cost and decide if its worth getting them, or S3 ones and some Whiteline MaxC topmounts and do it that way.
Sideways yo!
Offline jonnyc
  • Herrooooo!
« Reply #13 on: November 22, 2009, 01:58:24 pm »
The more you can get on the bottom arm the better really mate.. If you wind a load of camber on the top mount that alters the geometry such that the roll centre will drop a good amount (more than you would think) and you end up making the whole front end softer in roll..
The only downside is that you loose clearance from the inside top of the wheel to the strut.. But thats probably not a problem unless your trying to fit huge wheels/tyres in there..
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #14 on: November 22, 2009, 01:59:45 pm »
This is interesting... so what are the part nos?
