Author Topic: chirping sound from the engine  (Read 3176 times)
dansmith180
« on: January 11, 2015, 12:52:53 am »
As above there is a squeaking/ chirping sound from my engine, it's mostly on cold starts but a few times I've heard it after long drives still. It sounds like it's coming from the left side of the engine where the cambelt is, I have also WD40'd the aux belt and it didn't help.
I've done some research and it's probably a belt possibly cambelt but it was replaced 24k 27months ago so should be fine? Also I haven't heard of a cam belt still squeaking when warm?
Any suggestions welcome, thanks.
« Last Edit: January 11, 2015, 12:55:59 am by dansmith180 »
Redemption
Re: chirping sound from the engine
« Reply #1 on: January 11, 2015, 08:41:01 am »
One of the auxiliary belt pulleys perhaps? Had a similar issue on mine and that's what it turned out to be.
« Reply #2 on: January 11, 2015, 10:07:40 am »
Had the same noise and it was the auxiliary belt
Saintsteve
« Reply #3 on: January 11, 2015, 02:17:25 pm »
On the 2.0 TFSi, it's normally the cambelt tensioner that squeals when cold.
dansmith180
« Reply #4 on: January 11, 2015, 06:01:05 pm »
Its weird that it starts again though after a long drive? It was quite loud last night after nearly 2 hours of driving.
Saintsteve
« Reply #5 on: January 11, 2015, 08:02:27 pm »
If your cambelt tensioner wasn't replaced, this will be your problem.
Bearings can get very noisey, you are correct  :happy2:
dansmith180
« Reply #6 on: January 11, 2015, 08:11:32 pm »
I've just looked back through the service book and the toothed belt and toothed belt tensioning roller were changed at 34k in sep 2006 and the toothed belt tensioning roller + water pump were changed in Aug 2012.
Now I hope that they just didn't tick toothed belt on the most recent one otherwise the belt is 8+ years old but they would be insane to not change it when already in there?
I don't want to replace it for no reason but obviously don't want a dead engine.... My friend removed the aux belt today and it was still squeaking although much quieter.
dansmith180
« Reply #7 on: January 15, 2015, 05:12:07 pm »
If its a cambelt tensioner what sort of risk am I taking by not replacing immediately? If I was to leave it 2 months/ 1500miles is that a risk or is it most likely just an annoying noise that shouldn't cause any real issues? Thanks.
Saintsteve
« Reply #8 on: January 15, 2015, 06:50:50 pm »
I'll be just an annoying noise. It won't be a sign of imminent failure  :smiley:
dansmith180
« Reply #9 on: January 15, 2015, 07:02:11 pm »
Cheers  :happy2:
