Author Topic: Aux-in for rcd510  (Read 12538 times)
Offline usmangti
Re: Aux-in for rcd510
« Reply #30 on: February 11, 2015, 11:34:46 am »
Just been looking at the ebay item, on there it states rcd510 and rcd300, I don't understand why it would therefore work with the 310. When I receive mine, I'll try it with the 310 first if not, hopefully it will work with my rcd510. I'll post back if it woks or not!
Offline usmangti
« Reply #31 on: February 18, 2015, 08:15:15 pm »
So received the aux in today. Nice quality looks very OEM.
This is where it gets weird. I have a rcd310 and rcd510. I have being using the 310 as the 510s cd changer is knackered. Ideally I wanted to fit the aux to the 510 just cause it looks better, and then won't need CDs anyway. The aux works on the 310 but not the 510. Both stereos have aux activated. Apart from some distortion on the 510 when adjusting volume there is no sound being sent through. The head unit allows me to select AUX so it's defo picking up the connection.
I'm stumped as it's advertised for the rcd510 and the old version rcd300. As @Cossie Killer  was having problems with his 310 I thought it might be a different lead for each.
@vw55raz any ideas?
Offline Cossie Killer
« Reply #32 on: February 18, 2015, 08:22:04 pm »
Bloody weird, the noise distortion is exactly what i was getting.
Guy on eBay was very good actually, told him i was having issues and he's given a full refund. Could it be a coding issue? Something to do with the mdi combo loom?
Offline usmangti
« Reply #33 on: February 18, 2015, 08:27:21 pm »
Tell me about it.
This cable is utilising the cd changer slot and I believe the old style 30 pin iPod Dock uses the same slot. The mdi loom seems to uses what looks another quad lock connector. It did show MDI initialising for a few seconds when I first connected it to the 310 but not the 510.
Have you sent urs back? My pal wants one if ur flogging it. He's got an rns510. It goes tight in the dash so don't fancy chancing getting mine out now.
Offline K9
  • VW LifeStyle
« Reply #34 on: February 18, 2015, 08:28:17 pm »
my is just working fine. no problems here  :smiley:
Offline usmangti
« Reply #35 on: February 18, 2015, 08:28:42 pm »
Regarding coding, surely in my car if it's Worked with one and not the other then it must be a compatibility issue with the stereo itself??
Offline usmangti
« Reply #36 on: February 18, 2015, 08:29:30 pm »
What stereo mate? And did you have to do anything else additional or plug n play.
« Reply #37 on: February 18, 2015, 08:36:00 pm »
I may try to see if its a coding issue first
« Reply #38 on: February 18, 2015, 08:39:44 pm »
Actually I don't remember fitting it without the MDI loom, will try that if i get time. If it dont work, will give up and remove. The guy gave me a refund so your pal can cover the postage and have it foc.
Offline usmangti
« Reply #39 on: February 18, 2015, 08:54:29 pm »
Yeah defo have a play with it. But tbh I don't have an mdi loom anyway so not sure what difference that would make whether it was there or not.
Offline K9
  • VW LifeStyle
« Reply #40 on: February 19, 2015, 04:53:30 pm »
it's a Oem vw rcd510 dab 2012 model.
yes it was plug-n-play. i don't have a MDI kit. @usmangti
Offline andybon
« Reply #41 on: February 19, 2015, 09:45:58 pm »
Mine didn't work with my MDI kit, plugged it in and nothing at all happened!
How hard can it be?
Offline usmangti
« Reply #42 on: February 20, 2015, 12:12:51 am »
Cheers mate. Seems really weird how it works for some and not for others.
« Reply #43 on: February 20, 2015, 08:56:28 am »
Who did you get the MDI loom from Andy?
Offline K9
  • VW LifeStyle
« Reply #44 on: February 20, 2015, 03:42:10 pm »
will it work when un-plugging the mdi kit?
