Author Topic: Bluetooth module advice  (Read 4376 times)
Offline Cossie Killer
« on: January 13, 2015, 10:53:13 pm »
Ive got a MDI glovebox & bluetooth cable kit from DamoP and need to find a module to get it all up and running.
I have highline clocks and MFSW but only a RCD310 headunit (its my daily hack and does just fine), should I be aiming for a specific module?
Any tips?
Jason
Re: Bluetooth module advice
« Reply #1 on: January 14, 2015, 10:32:46 am »
Up for the day crew....
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: January 14, 2015, 10:43:22 am »
Ill have a 5n0 module for sale this week when I remove it from my car. It will work with highline clocks and will work with MFSW if you have a working menu button already
Offline KieranR
« Reply #3 on: January 14, 2015, 10:43:24 am »
Have a look through this thread. Modules are explained in it  http://www.mk5golfgti.co.uk/forum/index.php?topic=44094.0
« Reply #4 on: January 14, 2015, 10:02:59 pm »
Thanks for the link kieran but that thread seems to be specific to the 500 stereo.
What kind of usage and access can i expect with an RCD310?
Offline KieranR
« Reply #5 on: January 14, 2015, 10:47:39 pm »
I think with the RCD310 you will just be able to stream music to it from your phone.  I don't think you will see any phone details on the head unit.  I presume if you get a phone call or make one while connected to the bluetooth it will come through the cars speakers.  With the MFSW depending on the module you might be able to use the voice dialing feature.  I'm not sure about the voice dialling though. My MFSW does not support it
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: January 14, 2015, 11:03:13 pm »
The rcd310 will just say 'Phone' on the display but depending on what unit you have you can still use the highline menu to control your calls.
The 5n0 im going to sell soon will work but depends on what phone you have , I also have a fiscon unit which will do the same as the 5n0, but works with all phones and does music streaming.
« Reply #7 on: January 15, 2015, 12:36:39 pm »
Thanks for the replies, not bothered about music streaming as I've got the iPod connection in the glovebox.
Highline usability is a must, it has to have the same functionality as a parrot system as i seem to get inundated with calls too and from work for some reason.
« Reply #8 on: January 15, 2015, 12:38:40 pm »
Ps current workphone is a iphone5... Whatever upgrade i get will either be apple or android based, but would rather not have any connection issues based on handset...would pay extra for full availability.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: January 15, 2015, 12:59:55 pm »
if you want highline usability you would need either a 729B kit, or use a fiscon basic plus kit which will do everything
Offline SI-R32
  • -Receive: 126
« Reply #10 on: January 15, 2015, 01:04:27 pm »
Not strictly true as you can use of of these to use virtually all new BT modules with our RED displays
http://www.carsystems.pl/fis-link-can-box-converter-for-red-dot-matrix-fis-and-new-bt-modules,id687.html
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: January 15, 2015, 01:10:33 pm »
Oh yeah forgot about that option. a 7p6 unit and the above :D
« Reply #12 on: January 15, 2015, 02:16:01 pm »
I noted that Eddie mentions this on that fitting thread
Quote
'No messages with the 729B
I went back to a 5N0 version as I have upgrade my clocks, and it will do text messages in the highline
Quote
5N0 = (you must have a Highline and not an early one or you will be trapped in the phone menu. I tried this on a car with 972 cluster and mk6 wheel and was trapped. Works great if you have a working menu button. Displays on Highline + RNS, text messages in highline too and phone button works. very limited on phones that work with it
So sure the best module would be 5N0?
Unless Ive missed something (all very confusing lol.... should of bought a parrot kit)
« Last Edit: January 15, 2015, 02:18:14 pm by Cossie Killer »
Offline SI-R32
  • -Receive: 126
« Reply #13 on: January 15, 2015, 03:51:59 pm »
5N0 uses rSap to connect to the phone, i was reading somewhere the other day that other 3g services such as whatsapp and internet etc didn't work all the while the phone was connected to the 5N0 unit, plus your phone and future phones need to be rSap compatable.
The only good thing about 5N0 is it works straight away with red and white displays
if i were you i would go with a standard module like older 5k0 or newer 7P6 and just get the other module from carsystems.pl to use on red display.
much cheaper than 729B which i've had in the past plus newer modules give you audio streaming, like many people i thought i would never need this but with spotify and tune in radio and other streaming apps i constantly use it
a list of all modules can be found here
http://wiki.ross-tech.com/wiki/index.php/Telephone_Retrofitting
« Reply #14 on: January 15, 2015, 10:10:37 pm »
So worst case with the 5N0 is my whatsapp and internet wont work?! I can live with that being honest but Damian has mentioned the 1k0 module which doesn't seem to have been mentioned.
I wanted to keep it OEM but can see now why people sometimes choose a alternative aftermarket kit.
