Author Topic: Sidelight fell into projector depo headlight  (Read 1140 times)
Offline ruhaleali
« on: January 14, 2015, 08:17:07 pm »
Guys i tried to disconnect my sidelight and the bulb fell into the hole. What can I do to get this out. I am going to disconnect the head light tommorow and hopefully use a straw and nose pliers to remove this.
Offline Carpy25
Re: Sidelight fell into projector depo headlight
« Reply #1 on: January 14, 2015, 08:40:50 pm »
wire coat hanger with a blob of bluetac on will sort it , I always keep some bluetac handy good for holding screws etc to start them
Rob
Offline jaffa
  • -Receive: 44
« Reply #2 on: January 14, 2015, 09:17:57 pm »
My brothers fell in his xenons and took ages to get out as it became wedged inside
Personally I'd take the light off the car and tilt it until you can get a hold of the bulb
Offline ruhaleali
« Reply #3 on: January 14, 2015, 09:46:12 pm »
Can you ask him how he did it, I am going to leave it till summer then when the weather is normal just get it out. Now after uni I hardly get here with it going dark. ! :sick:
Offline jaffa
  • -Receive: 44
« Reply #4 on: January 14, 2015, 10:59:46 pm »
He ended up getting it out a when it moved from the front of the light to the back after he drove it for a few months.
Was just a case of waiting till you can see it and using anything you can to get a hold of it, I'm pretty sure we used a spring loaded grabber tool
We still needed to take the light off the car just to get proper access into the light
Offline ruhaleali
« Reply #5 on: January 15, 2015, 12:46:05 am »
Thanks pal Im thinking of ordering one will do once the bulb appears more atm you cant see it at all it so stupid pissed me off so badly today
