Author Topic: Central Locking  (Read 4463 times)
Offline ALIAHMET
Central Locking
« on: January 19, 2015, 11:01:26 am »
Hi
I am new to the forum and have recently bought a MK5 Golf 1.9 TDI
I noticed that the passenger door would not lock when using the central locking, after some research on this site and replaced the passenger lock module.
Now all the central locking works when locking on the key fob. However, only the drivers door unlocks when unlocking from the key fob. If I open the drivers door and press the unlock button on the drivers door, all will open.
I am guessing that, because all the doors now lock and unlock - that I do not have a locking module issue.
Is there some sort of reset that I need to do?
Any help would be much appreciated
Offline Callum45
Re: Central Locking
« Reply #1 on: January 19, 2015, 11:03:00 am »
You might have it set to 1 press on the button only unlocks the drivers door. 2+ presses opens the rest, have a go and see.
Offline ALIAHMET
Re: Central Locking
« Reply #2 on: January 19, 2015, 11:12:27 am »
Thank you for the quick response
Will give that a go and let you know the outcome - Cheers
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Central Locking
« Reply #3 on: January 19, 2015, 12:44:27 pm »
Do you have highline clocks? You can change the settings to open all doors or open single door with lock.
If you don't have highline clocks you need either the carista app or VCDS
Offline ALIAHMET
Re: Central Locking
« Reply #4 on: January 19, 2015, 02:00:42 pm »
No unfortunately I don't have the high line clocks, I presume these are the large LCD display in-between the clocks.
With these apps, do I need additional cables to plug my laptop to the car? if so how much do these apps and cables cost?
I will try pressing the button twice on the key fob when I get home from work tonight
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Central Locking
« Reply #5 on: January 19, 2015, 03:54:36 pm »
You need an obd adapter which can be purchased from eBay for around £5. You then need the carista app which costs around £10
Offline paulw123
  • -Receive: 47
Re: Central Locking
« Reply #6 on: January 19, 2015, 03:58:08 pm »
I find the double press a real pain. Usually my door opens and I get in, then realise everybody else is still outside standing in the rain....oops :rolleye:
Offline ALIAHMET
Re: Central Locking
« Reply #7 on: January 19, 2015, 06:09:33 pm »
Yep, the double button worked  :happy2:
I can live with pressing the button twice, unless there is someone near the Lakeside shopping area who would not mind programing the car to open with one click on the key fob
Also to program my second key to work too
