Thanks lads, mine is 105bhp at the moment... wouldn't mind getting a few more horseys though
I had a 1.9 105 before
PD130 injectors
darkside gtb1756 kit on a cast manifold
full 2.5 inch tbe no silencers etc
uprated clutch and single mass flywheel
gave me 221bhp and 365lb ft on darksides very honest dyno and gives real world figures!
(for reference my scirocco did 194.2 on darksides dyno and did 203 on another local dyno and 340lb ft on dsd and 385 on the local one).
handling mods, arbs etc.
many many things.
someone linked my thread above, most of the pics are broken because imageshack ruined everyones lifes.
engine costs
remap to about 150bhp = 300 quid
pd130 injectors approx = 200 quid
injector seal kit (you MUST get this) = 85 quid and fitting is fiddly be careful who you get to fit them as if they're not timed properly it will run crap
gtb1756vk kit with fitting and mapping etc = think it's 1700+ vat so approx 2200
egr delete = 80 quid
clutch = 700 + fitting
you also need much better brakes, r32 set up at the very least, so you need to swap the front hubs and fit 55mm suspension components, and other bits and pieces. better suspension, bushes, anti roll bars etc..
