Author Topic: Anyone installed rear coilovers like this?  (Read 6276 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Anyone installed rear coilovers like this?
« Reply #15 on: January 22, 2015, 07:22:36 pm »
They are installed both ways....depending on the maker. The top adjuster type simply fit over the the bump at the spring's top mount and the bottom adjuster type are usually bolted through the lower swing arm.
Offline Polo6n1600i
« Reply #16 on: January 23, 2015, 10:03:50 am »
FK's are either way up, but i put them at the bottom. yes it would be more difficult to adjust - but once your happy with your ride height how often are you going to really change it? Plus i found it easier to just drop the lower arm - adjust the height then bolt it back together!
Offline xjay1337
  • -Receive: 377
« Reply #17 on: January 23, 2015, 10:08:15 am »
The adjuster SHOULD be at the top.
Offline jaffa
  • -Receive: 44
« Reply #18 on: January 23, 2015, 02:49:24 pm »
My FK's are the same, I wasn't a fan of the adjuster at the top
Only takes me 5mins a side to adjust once the wheels off
Offline Stanipkiss
« Reply #19 on: January 23, 2015, 08:51:49 pm »
My Apex RDX's are at the top!
Offline K9
  • VW LifeStyle
« Reply #20 on: January 24, 2015, 10:16:35 am »
will be installing my kw's next week or 2 weeks.
Installing the adjusters at the top i kinda new to me as i had a mk4 gti golf before this with AP coilovers, btw how are KW's compared to AP coilovera?
