Author Topic: New 7R to replace the MK6gti  (Read 62319 times)
Re: New 7R to replace the MK6gti
« Reply #150 on: April 14, 2017, 01:27:57 pm »
Not sure mate .. they are all rusty anyway
Weren't they 2 piece?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #151 on: April 14, 2017, 06:02:33 pm »
Not sure if you really check this thread anymore but I will post anyways. Saw the car at Vag Tuner today and looked awesome especially on trackk  :happy2:
Thanks for the pics Dan,
Was having problems on track that day, blew a boost pipe to pieces and kept going into limp mode by shutting a cylinder down :(
We have tried allsorts to try and cure it and is back in as we speak,
it seemed to of started when the cooler was changed ?
Basically it registers a misfire and shuts a cylinder down, was always on no:3,
Changed coil packs
changed injector on cyl 3 (then the misfire went to no:2)
tried 3 different types of plugs
done bore scope (all fine)
comp test (all fine)
Smoke test for leaks (all fine)
General check on all wiring connections
Latest stage 2 Revo Map
back top old stage 2 Revo map
Tried stage 1 map
loads of logs, and shows the odd misfire on all cylinders, fuel pressure ok, boost levels all good,
Rev it to around 6.8k and bang cylinder shutdown :( it is now moving around and shutting down cylinder 1,2 or 3
Really starting to piss me off now .. Going to try putting the standard cooler back on.. on Monday or maybe try stock map 1st ?
Ive got a Ring trip coming up this week, so really need it sorting now (its runs great if not revved to 6.8k)
Any ideas greatly appreciated :)
@Neilgti  Bit late with this now, but did you get to the bottom of the misfire? Could it have been the valve spring float?
http://www.mk5golfgti.co.uk/forum/index.php/topic,100020.msg982222.html#msg982222
I'm suffering with a similar problem  :sad1:
Offline Neilgti
« Reply #152 on: April 14, 2017, 06:24:50 pm »
Changed coil packs
Tried stage 1 map
Thought we had got to the bottom of it, after loads of logs etc, it was overfuelling all the time higher in the rev range .. which was making it run really rich when pushing on,
Changed the ECU and this cured it, or we thought it did ?
It was happening that often I could replicate it all the time,
After the ECU change .. I couldn't replicate it,  so I booked in at Cadwell to make sure, few laps in same old story !!
Hence why I've now got the Clubsport lol
Really good shout on the valve float after reading that would of been my next port of call,
Hope you get yours sorted pal ..
I just totally lost the plot with mine
MK5 GTi
MK5 R32
MK6 Gti, all gone but not forgotten
Now loving the 7R
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #153 on: April 14, 2017, 06:42:55 pm »
Thanks Neil  :happy2:
Mines slightly different in that it's not cutting the cylinder like your's was, just missing like mad when over 6K. Hope new valves will sort it or i might be out for a clubsport myself  :laugh:
Fantastic choice mate, enjoy  :driver:
Offline Neilgti
« Reply #154 on: April 14, 2017, 06:50:22 pm »
Thanks pal and good luck with yours
MK5 GTi
MK5 R32
Now loving the 7R
« Reply #155 on: April 14, 2017, 08:15:09 pm »
Maybe looking at the R8 V10 springs, cheaper than the likes of super tech etc
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #156 on: April 15, 2017, 07:48:05 am »
Thanks @Tfsi_Mike only really looking into it now, so only come across APR's offering at like £800  :scared:
Are the R8 springs something Alex would have mentioned? Is it a common replacement? Must do some research...
« Reply #157 on: April 15, 2017, 08:07:03 am »
Alex is aware of them but I don't know if it's something he would recommend over super tech.  They just seem to be much better value for money to me.
Offline gulfstream11
« Reply #158 on: May 02, 2017, 12:33:59 pm »
Hey up mate.
Saw you charging round the ring following a stretch limo. Well not exactly charging but looking good.  :driver:
« Reply #159 on: May 02, 2017, 05:31:56 pm »
« Reply #160 on: May 03, 2017, 07:56:06 am »
Yup.. Thats the one..  :signLOL:
Offline Neilgti
« Reply #161 on: May 06, 2017, 09:46:09 pm »
Hey up mate.
Haha yes that was so funny filming that, great set of Lads
7 Welsh kids plus luggage
13.29 btg
MK5 GTi
MK5 R32
Now loving the 7R
Offline Neilgti
« Reply #162 on: May 06, 2017, 09:47:25 pm »
Great shot of the Clubsport
MK5 GTi
MK5 R32
Now loving the 7R
« Reply #163 on: May 08, 2017, 11:16:55 am »
Awesome....   13.29 :rolleye:
Offline Neilgti
« Reply #164 on: May 08, 2017, 11:28:14 am »
7.55 in the CS with 2 passengers and nearly a full tank of fuel ..
it just wants to go all the time and loves been in the top of the rev range, and the trick diff works really well
MK5 GTi
MK5 R32
Now loving the 7R
