November 18, 2024, 09:36:40 pm
All Things Mk5
Mk5 General Area
Help removing centre caps
Topic: Help removing centre caps (Read 2969 times)
VW_Jace
Always Involved
-Given: 2
-Receive: 0
January 22, 2015, 10:04:30 pm »
Went to replace the wheel caps in my wheels but they don't seem to come off very easily and when I did mange to pull at it the front facing came off but not the whole cap? I've just had the wheels refurbished so am nervous to go prodding around too much! Any advice on an easy way to pull them off?
GTi-Andy
Won't Shut up.
-Given: 20
-Receive: 17
Re: Help removing centre caps
Reply #1 on:
January 22, 2015, 10:06:53 pm »
I would say, take the wheel off and push from the other side
So much for keeping it standard!
VW_Jace
Always Involved
-Given: 2
-Receive: 0
Reply #2 on:
January 22, 2015, 10:09:39 pm »
Was trying to avoid doing this but if it's the only way then maybe it will have to be! I was thinking of getting a suction rod and pulling it off lol
andybon
Won't Shut up.
-Given: 11
-Receive: 8
Reply #3 on:
January 22, 2015, 10:10:30 pm »
As said, safest way is to hit them from behind
How hard can it be?
Alex157_gti
Always Involved
-Given: 1
-Receive: 3
VCDS 2015 Edition
My Ride:
Reply #4 on:
January 22, 2015, 10:20:03 pm »
Get a small screw driver n jam it thur middle n shud pull out :) bang it in with a hammer
2005 Gti Black 18" monzas, full leather, sunroof, sat nav, heated seats. highline, high spec
Sheffield.
VCDS 2015 Edition Hex+Can Can help out
MC71
Just look at my post count
-Given: 413
-Receive: 427
Mk7 R
My Ride:
Reply #5 on:
January 22, 2015, 10:24:01 pm »
Wheels off and push from behind or bore a hole in centre and pull off.
theneilster
Can't Read PM's Yet!
-Given: 0
-Receive: 1
Reply #6 on:
January 23, 2015, 07:19:43 am »
Self tapping screw through and pull out. But as mentioned taking the wheel off is the best method I found!
lol first post!!
(first thing I can actually impart some of my limited knowledge!
Matthewsimone
Won't Shut up.
-Given: 52
-Receive: 39
Reply #7 on:
January 23, 2015, 07:34:46 am »
I just stabbed a pointy pick through centre of mine yanked them off and fitted new ones, 2 mins for whole job
Shoy1980
Always Involved
-Given: 5
-Receive: 18
Reply #8 on:
January 23, 2015, 08:20:50 am »
Try using a suction cap.
jameseddie
Just Arrived
-Given: 0
-Receive: 0
Reply #9 on:
January 23, 2015, 12:22:32 pm »
Quickest method, drill a hole. Otherwise take the wheels off and then seal them.
H18Golf
Always Involved
-Given: 0
-Receive: 10
Reply #10 on:
January 23, 2015, 04:44:02 pm »
As already suggested, if these are going to be binned then hammer a small flathead screwdriver through the middle of them and pull out, or drill a hole, easy job.
raven8472
Always Involved
-Given: 10
-Receive: 0
Reply #11 on:
January 23, 2015, 07:59:42 pm »
I replaced mine with a set from VW.
Slow drilled a Phillips/ Cross screw into each center cap and pulled off using the screw. Took about 5 mins to remove all 4 and replace with new ones.
VW_Jace
Always Involved
-Given: 2
-Receive: 0
Reply #12 on:
January 26, 2015, 05:47:53 pm »
sorted this today guys, by whacking a pointed screwdriver in the cap and pulling it out.
cheers!
Johnboy2110
Always Involved
-Given: 10
-Receive: 2
Reply #13 on:
January 26, 2015, 09:51:14 pm »
What size are the centre caps? I need to change mine
VW_Jace
Always Involved
-Given: 2
-Receive: 0
Reply #14 on:
January 27, 2015, 08:45:07 am »
65mm, cost me £7 for four on eBay
All Things Mk5
Mk5 General Area
