Author Topic: top mount bolts  (Read 1481 times)
Offline Danbear79
top mount bolts
« on: January 22, 2015, 10:15:18 pm »
Ideas needed... tonight i went to fit my coilovers but 1 of the 3 bolts on the strut tower is kaput. After lots of trying to remove the bolt and knackering the bolt on the underside, i still can't remove it. Is it a case of drilling the bolt out from the top? Really wasn't expecting this,  so any ideas will be appreciated
Offline scottharvey
Re: top mount bolts
« Reply #1 on: January 24, 2015, 06:18:26 pm »
I had same just use a air chisel or if not just a lot of welly and a hammer and chisel
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: top mount bolts
« Reply #2 on: January 24, 2015, 06:55:07 pm »
I had the same too. Drilled it out
Offline Danbear79
Re: top mount bolts
« Reply #3 on: January 26, 2015, 02:32:14 am »
Glad I'm not the only one haha. I drilled it out in the end and greased them up when re fitted
