Author Topic: Advice on gti seats  (Read 1403 times)
Offline Wooly46
  • My Ride: Gt Tdi Sport
Advice on gti seats
« on: January 24, 2015, 05:24:00 pm »
I've got a mk5 gt tdi sport which has the full leather Gti interior and I was wondering what the electric switch does on the side of the seats? I have the lever at the sides to jack the seat up and down and a lever at the front to move the seats forwards and back, so what are they for? At the moment they don't do anything so I guess whoever fitted them has missed something out and I would like them to work as they should! Any help would be appreciated, Cheers
Offline mvb12
  • -Receive: 64
Re: Advice on gti seats
« Reply #1 on: January 24, 2015, 05:25:20 pm »
lumber
Offline Wooly46
« Reply #2 on: January 24, 2015, 05:32:18 pm »
lumber
I guess they aren't wired up then? Do you know if I need an additional loom or something?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: January 24, 2015, 07:12:25 pm »
Maybe the wrong loom was used to retrofit them or check the fuse. Do the heaters work on them?
Offline Wooly46
« Reply #4 on: January 24, 2015, 07:43:01 pm »
I didn't know it had heaters!!
Offline skard
  • -Receive: 245
« Reply #5 on: January 24, 2015, 07:50:32 pm »
Lumbar just needs a 12v if I recall
Offline Wooly46
« Reply #6 on: January 24, 2015, 09:07:48 pm »
Any tips what I can do to sort it?
Offline skard
  • -Receive: 245
« Reply #7 on: January 24, 2015, 09:12:28 pm »
Do you have a plug like this under your seats?
This is for heated seats.
If you have heated seats but not wired up, Kufatec sell a loom for heated and electric seats.
Otherwise, if you just need a 12v supply for lumbar, buy some repair wires and plug them into the fusebox, run the wire under the carpet and to your lumbar for both sides.
Bit odd they are not wired in but the rest is, have a scour for unused plugs etc and post them up if you find some.
Offline Wooly46
« Reply #8 on: January 24, 2015, 09:17:36 pm »
I'll have a look when I get chance. I don't have any switches on the dash to switch on the heated seats so I guess I'd have to get them too?
Offline Wooly46
« Reply #9 on: January 24, 2015, 09:20:02 pm »
Where would the connections be for the lumbar? Would they be a plug in connector?
Offline skard
  • -Receive: 245
« Reply #10 on: January 24, 2015, 09:20:32 pm »
Before you buy anything, look under your seats for this box. If seats are up to 2006 then both sides will have one, if after then only passenger side has it.
If this box isn't there, then the seats aren't heated.
Offline skard
  • -Receive: 245
« Reply #11 on: January 24, 2015, 09:23:06 pm »
It should be part of the big plug I put a picture up of.
It has its own fuse so check it hasn't popped.
Offline Wooly46
« Reply #12 on: January 24, 2015, 09:32:04 pm »
Would the fuse be amongst the others?
Offline Wooly46
« Reply #13 on: January 24, 2015, 09:33:16 pm »
Apologies for all the questions, newbie to the golf :wink:
Offline skard
  • -Receive: 245
« Reply #14 on: January 24, 2015, 09:36:00 pm »
The fuse number will be in the handbook and it is to the right of the steering wheel behind a D shaped panel, though if it was a retrofit they could have used any spare socket.
Best use a torch to see if you have an obviously burnt out fuse.
