Author Topic: MFSW and highline clocks fitting.  (Read 6725 times)
Offline andybon
Re: MFSW and highline clocks fitting.
« Reply #15 on: January 25, 2015, 09:50:47 pm »
Cool, will start to get everything together and find someone local to me to code them up (in St. Helens/Warrington)
How hard can it be?
Offline andybon
« Reply #16 on: January 27, 2015, 05:09:53 pm »
Just wandering if the steering wheel controllers will need coding to each car or are they interchangeable?
How hard can it be?
Offline skard
  • -Receive: 245
« Reply #17 on: January 27, 2015, 06:18:18 pm »
They are coded depending on your spec, not VIN.
Unless you happen to buy a used one from a car with exactly your spec, it'll need recoded
Offline andybon
« Reply #18 on: January 27, 2015, 09:24:43 pm »
That's good to know  :happy2:
Is the best way to see what is on them to fit them or can you scan them to see?
Sorry for the mither, can't find anything with the search function on here!
How hard can it be?
Offline skard
  • -Receive: 245
« Reply #19 on: January 27, 2015, 09:26:48 pm »
Not sure what you mean  - do you have VCDS access?
Offline andybon
« Reply #20 on: January 27, 2015, 09:49:02 pm »
Just to see what is coded on the steering wheel controller. I don't, I'm on the lookout for someone in the north west area.
How hard can it be?
Offline skard
  • -Receive: 245
« Reply #21 on: January 27, 2015, 09:54:51 pm »
Don't worry too much about researching the old car, once you find someone local with VCDS they can code it to yours.
Offline andybon
« Reply #22 on: January 27, 2015, 10:00:13 pm »
Cool, probably all daft questions, but I can't seem Torino answers for them lol.
Think the only thing I haven't got is the slip ring, just hope mine is fine!
Thanks for your help, :happy2:
How hard can it be?
Offline nadlad
  • GT Sport 08 140PS
« Reply #23 on: January 28, 2015, 12:02:29 am »
Na just get a CH controller from china
Ebay this part number
1K0-953-549-CH
Or
http://m.ebay.co.uk/itm/231464615510?nav=SEARCH
I have highline clocks for sale too.
« Last Edit: January 28, 2015, 12:07:00 am by nadlad »
Offline andybon
« Reply #24 on: January 31, 2015, 11:10:02 am »
Am I ok to remove my current clocks and plug my new ones in just to see if they work, then refit my current ones.
Want to make sure it all works before the day comes when I put it in and find out its dead!
How hard can it be?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #25 on: February 01, 2015, 03:15:20 pm »
You will have Xmas tree on the dash. Lot of warning lights
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline andybon
« Reply #26 on: February 07, 2015, 12:59:41 pm »
Right, day come to do the wheel, and I've hit a problem.
The mfsw harness I got is too short between the 2 connections on the back of the airbag (looks like this is between the horn) tried to modify with a new wire but then noticed all the connections are different!
Part number I had is 5K0 971 584C, is this the right one or have I ordered the wrong one, is so what is the correct one?
Also I have slipring part number 1K0 971 653C. Will this work, or will it need changing?
How hard can it be?
Offline skard
  • -Receive: 245
« Reply #27 on: February 07, 2015, 03:02:25 pm »
5K0 is for a mk6 wheel
You want 1K0971584C
Offline andybon
« Reply #28 on: February 07, 2015, 03:18:05 pm »
to top it off, swapped controllers over and nothing  on the wheel worked, power steering light was on so swapped back and light is still on! Even took it for a drive and it's still there.
Coming close to giving up on this now, really frustrated with it!
How hard can it be?
Offline andybon
« Reply #29 on: February 07, 2015, 05:08:40 pm »
Looking through eBay they all seem to say mk6 golf, can't see any for a mk5!
How hard can it be?
